What Volume Headunits Clip At
Anyone have info on the Jvc kd-apd49 single din?
1995 Nissan Maxima GLE
JVC KD-APD49 Headunit
(4) Infinity Kappa 652.9i components @ 2 ohm
(1) Infinity Reference 475a amplifier
(2) Skar Audio V-VXV1 12D4's
Hifonics Brutus 2100.1 @ 1 Ohm
Via my DD-1 my CDA-9887 is clip free to 35 full, EQ and Xovers set to flat with Subout Max +15, using the DD-1 Test Disc. I also want to point out something, just because someone has tested your brand/model of unit, that is NOT a perfect indicator of what YOUR unit will do. Examples are my unit the 9887 some get distortion much lower than I do. So keep in mind when you are asking what does this or that unit clip at, what you read or get a response of should be taken with a grain of salt, as your unit may be slightly or greatly different. QA is not good enough at these manufacturer's to say ALL of this brand/model will clip at this volume level.
The best way to find out is get your unit tested with either an O-Scope or a DD-1.
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
  • Who's Online   0 Members, 0 Anonymous, 809 Guests (See full list)
