What I need help figuring out is. Are kappas 2 or 4 ohms. Infinity claims they are 2 ohm but put a "true 4 ohm load" when you add in resistance. How would I wire two sets of these up on 2 channels on a amp. Would series be a 4 ohm load or 6 ohm load? Would parallel be a 2 ohm load or a 1 ohm load?
Edited by Robert8252
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
I'm running my kappa 6x9 and 5 1/4 at 2 ohms.
2006 Nissan Z Track.
My Feedback Thread
there 2, i beleave all if not most infinitys are 2ohm
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
mine were 2ohm too. my guess is for efficiancy purposes but not sure. if the sets are all the same then you can wire them up to a 2 channel, if dif sizes etc not the best idea(i did it for a bit but the smaller cant take the power good)
Ya that set is 2ohm. And its to get more power for those who just run off H/U or thats what i have been told.
(2)12" Rockford Fosgate P3's
(1)AudioQue 1200D
(1)AudioQue 4x90
6.5" Infinity Kappa Components
(2)6" Elemental Design e3.6's
6x9 Infinity Kappa Coax
JVC Arsenal H/U
hmm never thought about that. But i do know that some head units are not 2 ohm stable. maybe thats why my buddy's stock mazda 3 radio kept blowing fuses lol.
Eclipse cd7000
cant wait till i can afford em
03' NISSAN XTERRA
(1) AQ3500d
(1) AQ4x90
(1) Audio Control Line Driver
(4) DC LVL 4 15's
Cresendo Mids and Highs
100' of 0/guage
Big Three
Mechman 270a Charging @ 16.5v
(6) XS D1400's
Highest Termlab Score 149.9 at the kick & 166.1 in the Port/ on stock electrical and 1 DC XL M1
Updated JUNE 2012*****MY BUILD LOG
USACI REGION 6 POINTS LEADER 2011
USACI KANSAS RECORD HOLDER 2011
Team DC
http://www.dcsoundlab.com/
They are 2ohm because your factory wiring is (in theory) suppose to add 2ohms in addition; thus your amp "sees" close to a true 4ohm load, or lower. Thus, simple speaker swap= more power output/higher spl.
We all know wire adds resistance; maybe not much, but when you are trying to get the most from everything this little trick could prove great technology for car audio.
lol, decks can run @2ohm stereo if need be
pioneer makes some decks with the rear channels to be able to be bridged @4ohm to a small sub
i ran my pioneer 4700 @2ohm stereo and it worked ok, i had coax's up front and in rear wit cheap tweets added to em cause how the factory mounted the speaker u couldn't hear the tweet so i had to add some somewere else
but in thery a fullrange mids n highs amp can be ran at a lower ohm than a sub amp due to 6&1/2's dont need much power to get em moveing and my buddy ran a 2ch @1ohm stereo that was 2ohm stable and had no problem wit it so i unno, u could try it
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
x2 they are 2ohm, had me comfused too at first when I was buying replacement tweeters. (got a bad 1 in one of my sets broken wire or something and bought off ebay no warraty)
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
  • Who's Online   1 Member, 0 Anonymous, 4382 Guests (See full list)
