SQMonte Posted September 30, 2011 Report Posted September 30, 2011 Didn't disconnect battery power when connecting amp. Arced screwdriver from Bat+ terminal to amp case. Amp go poof. I did same thing not too long ago, except it wasn't while installing the amp....I was troubleshooting and part of that included me swapping the speaker leads from one set of channels to the other, accidentally arced the screwdriver just like you said (except I was on the negative terminal of one of the speaker connections) and blew the pico fuse in my deck. It's all good though, I like my CDA-117 better. Amp made it out unharmed. Alpine CDA-117...Memphis 16-X03 CDT Audio SQA-4100...SEAS Prestige H1396...Crescendo MP-6 Soundstream Rubicon 1.2500d...Digital Designs 3512f
BassJunkie Posted September 30, 2011 Report Posted September 30, 2011 Buying cheap anything, especially rca's...bought atleast 4 sets of scorsche rca's before I bought a good set and I'll turn back. 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router.
Esaul Posted September 30, 2011 Report Posted September 30, 2011 Here's my list... At 16 I bought a pyle 1400 watt amp. A Kenwood sub (still work great actually...) A shittyy Panasonic cd player.. and had a friend that knows how to install it in my s10...in the end... My gauge lights didn't work and no working cd player.
poorfish88 Posted September 30, 2011 Report Posted September 30, 2011 Back in 89-90ish, I installed a small Alpine 3522 amp 60watts 4ohm on two Kenwood tens. The shitty tens in the factory made truck boxes with the tweeters in them. I used 10 guage wire for the amp (at the time I thought was gaint) anyways I went to the Auto parts store and bought my fuse holder. Now the problem it was wired already 18 gauge, Needless to say that Shit melted but didn't blow the fuse.
kirill007 Posted September 30, 2011 Report Posted September 30, 2011 Spending more money than you have.. Thinking is the root of all problems... You ALWAYS get what you pay for.
AA98hoe Posted September 30, 2011 Report Posted September 30, 2011 When I was installing at shop few yrs back out of thousands of installs the 2 major mistakes I made were. I was installing flip down tv in a expedition. I grabbed power from ign harness under dash and didn't fuse when I was installing all trim back the grab handle in the back b pillar pinched it and it acted like a dynamite fuse the wire turned red hot and burned through factory plastics and running board in seconds untill I pulled the wire from the t tap on the ign harness. 2nd was I was drilling a hole in a 90s burban through the passenger lower firewall for 0g and hit the a/c line with a brand new drill bit it puntured and dumped all the freon charge in the shop. Lol TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
1988JimmyRE Posted September 30, 2011 Report Posted September 30, 2011 Just recently started a build, saved my money for a few more weeks (been saving for 3 years)just to be sure this Jimmy would be sound enough to drive, ended up doing a full tune up to be sure! Everything was good (285,000) miles.... Anyway i ordered all my equipment then my engine blew head gaskets and some rings went out on me... Just my Luck, So now i have to get a new motor, replace (will be a bigger motor cause it's literally cheaper and a lot better that way ) before i can hear my stuff, oh well patience patience patience. BUILD LOG-->1988 S15 Jimmy V8 4x4 2 15" RE Audio<--BUILD LOG
photochrisb931 Posted September 30, 2011 Report Posted September 30, 2011 I cant tell you how many times I have face palmed doing half of what you guys have posted. I have forgotten to hook up rca ran screws thru remote and speaker wires no bracing and popped screws. The funniest was about 17 yrs ago when I was a complete noob to car audio and decided to do my first multisub install. I bought four 8 in series 1 Rockford subs. The box was marked 4ohm on the side. Well I series paralleled them on the back 2 channels of my amp and they did not hit nearly as hard as my previous series 1 10s. I was like wtf. Finally took it to the shop because I was pissed at myself especially when they pulled one out to check my wiring and it was wired correctly but my subs where 8ohm. Not completely my fault the box said 4 , must have been a bad day for a packager in AZ. I felt like an idiot there in bright red was 8ohm on the magnet total fail on my part for not paying attention. Barstad
LT.Smoke Posted September 30, 2011 Report Posted September 30, 2011 Setting my amp improperly with 600 watts going to a 8 in a Tline lol... I will admit i SUCK at tuning Team MaxRetribution Si Vis Pacem Parabellum Id rather be judged by 12 than carried by 6 Bowhunting- Life Begins and Ends at Full Draw Bowhunting Team Fatal Trajectory Hunt Team http://www.stevemeadedesigns.com/board/topic/49335-sick96vtecaccords-t-line-build/?hl=sick96vtecaccord << Accord Build http://www.stevemeadedesigns.com/board/topic/68498-smokedout08impalas-tline-build/?hl=+sick96vtecaccord << Impala T-line build Rebassed.com for all your music needs 👌
Nine8SST Posted September 30, 2011 Report Posted September 30, 2011 My BIGGEST mistake was buying all new gear after being out of the "car audio loop" for ten years....without researching!! I assumed what was "good" then, was still good. Not the case at all......so, I ended up selling almost everything and starting over. It's crazy how quality changes and things evolve over the years, including the level of knowledge in some of the young guys.....well those who dont have thier heads up thier asses anyway. There is always something new to learn! 1998 SS/T Ram Build Log - Kenwood KVT-514 and KNA-G510 Navigation - 2 DC Level 3 12" - Components??? - Sundown ??? - Sundown??? - Knu Konceptz - Second Skin Dampy Pro - XS D6500
