It may be on here somewhere else, so just post a link and I'll check it out. But if not, what are the main diff's in the separate lines of Sundown amps??
Man I'm glad I didn't lock this I get to witness two retards holding hands telling each other that it'll be ok because they are awesome.
If I'm not mistaken I believe where they are built, but for sure I know that the SAE models don't go below 1 ohm.
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
Well the SAE amps are Chinese made and don't run below 1 ohm or above 15 volts IIRC. SAX amps are Korean amps and are the multichannel amps (except the new SAX1200D). The SAZ amps are Korean made as well but are the stronger, bigger monoblocks. They run under 1 ohm and up to 18 volts.
That may not be totally right, but until someone says different I'm sticking to it.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
sae 1200 will put out more power than a saz1500 from what db-r has told me
DC.jpgDC POWER
Yeah, Jacob has said that it could legitimately be called a 1500 watt amp, and it put out over 1700 watts in his clamp test before the fuses blew.
Pioneer DEH-P6000UB
Sundown SAX-50.4
Sundown SAX-1200D
Stock Bose system
Profile AP1000M
Hum, hum !?
I don't think so !
The saz 1500 is a real beast.
The sae is the entry line, they can't be strapped.
And the saz is the competition line, the amps are strappable.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Strapping doesn't have anything to do with it. The 1200d is simply underrated. I'm not sure it'd do more than the 1500d, but it's a stout amp nonetheless.
Edited by R_Mac_1
Pioneer DEH-P6000UB
Sundown SAX-50.4
Sundown SAX-1200D
Stock Bose system
Profile AP1000M
um nooo wasnt the saz1500 putting out like 1900 at 12volts in a test so no the sae1200d is not stronger then the saz1500d
and the saz1500d at .5ohm easily puts 2k out and not getting very hot. tough ass amps
Depends on the load - with a high impedance rise the 1200D will do just that. The 1500D excels at lower loads and will put out more in the end when wired down.
Thats what i meant, wired at 1 ohm with some rise. Db-r mentioned i should have got D2 subs and ran my 1500 at .5. which is not under warranty of course :drinks:
DC.jpgDC POWER
  • Who's Online   0 Members, 0 Anonymous, 1747 Guests (See full list)
