Fi Car Audio
always been curious and wenever i get to the fi website im not findin it...anyone know what they are? someone tried telling me they were 200oz magnets but i highly doubt him
2007 Cadillac Escalade
Alpine Headunit
Infinnity Kappa 6.5" components powered by 250.2 kicker amp
Currently sitting in my garage waiting to be installed:
3 18" Ascendant Audio Mayhems
3 Rockford Fosgate T40001bds
6 kinetiks batteries
dual 300 amp alternators from Iraggi
Im wondering why the weight of the magnet is in question or even a concern?
Its a single slug magnet that is stronger then the old triple and double slugs.
I wouldnt imagine Fi would go with a lighter weight magnet if they where not able to keep the magnet force at the gap as strong or stronger ;)
magnet weight is totally irrelevant to anything...they are 11.25" in diameter with a single slug
Authorized Ascendant Audio Dealer! Message me for information.
If you can't explain it simply, you don't understand it well enough -Albert Einstein
"I have a plausible excuse for not liking you. And you know why."
its not totally irrelevant. what if he has a really weak box? or maybe he is really weak....
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Then he needs total weight, not magnet size. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
well with cheaper subs it is, because some of them have the same magnet weight as like 6x9's :/
but for these high end subs, its only important to know because of how to brace the box cause a cheap prefab with a 50 LB sub = broken box quickly
F/s: 2 custom made boxes, for 1 12" and 2 12" hit me up I'll let em go cheap
If you are buying a BTL and don't put it in the proper enclosure that's your own stupidity anyways :)
They're about 70 pounds crated...
i can answer this...
how big are the magnets on the new btls?
Not big enough :)
this, and you would p
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
