I run 2 of the SA-12's with a SAZ-1500D wired to 1 ohm and they work fine. Those SA-12's will handle that amp no problem
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
As long as you don't stupidly set the gain you'll be fine. And if you do set the gain improperly, your subs and amp are probably screwed anyway.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
id go wit the 1 ohm those amps are beastly an the subs are awesome they can take that amp all day if u set ur gains right
kia spectra 4 door
HU-a kenwood kdc-692x
optima red top under the hood ( kinetik battery or powermaster in the back )
Iraggi 260amp H/O alternator
1 set of knu kandy 1/0 guage wiring kit ( 2 more sets coming )
front speakers -
back speakers -
2 12" lv 4's with lvl 5 softparts ( going to be 4 in near future)
Sundown 3500d( going to be 2 sometime )
i have boughten from - Bass14(smd), ddbump(caraudioclassifieds)
Should the gain be set at 1/2, 1/4? Somewhere in between. I guess my questions would be what is safe to set it at?
Kenwood kdc-x794
Boston Acoustics S60 components, S65 Coaxials
Jl J2-320.4
Sundown Audio Sae1200d
2 Sundown SA-12's D4
Car Quest NGT Extreme Upfront
Shuriken BT-60 inback
Big3
All Knu Konceptz wire
get a oscope an set ur gains that way u can tell when ur starting to clip an when ur not an its safer then using your ear just no what sounds ur subs make in case u go to far
kia spectra 4 door
front speakers -
back speakers -
  • 13 years later...
On 4/23/2024 at 12:46 PM, Mikefenzel92 said:
Can i change my d4 sundown sav2 to a d1 and be ok?
It comes down to the minimum stable impedance your amp support, for a D1 wired in parallel you would need a 0.5 ohm stable amp.
  • Who's Online   1 Member, 0 Anonymous, 1618 Guests (See full list)
