Like the title says, would you go with the biggest or smallest recommended enclosure for a sub, and why?
I know with a smaller box you could feed a sub more power, and I've heard that you could only give a sub it's recommended RMS in the biggest recommended box...
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
If you're not running RMS of a woofer use a smaller box this yields better results with less wattage, if you want to over-power or run RMS build max specs. thats my .02 cents
Team Bassick
HU: Pioneer DEH-4200UB
Front: Pioneer TS-A1683R
Rear: Pioneer TS-T110
Amp: Kicker KX600.4
Subs: PSI 18" Platform 1
Amp: Audiopipe 1500D
Electrical: Big III, Stinger SPV-40, Stock ALT
SCORE: N/A
Makes sense....though I remember reading that it would be safer to have a smaller box if over-powering a sub...I guess not....
Thought so......
Starting to get confusing....
My boxes I build usually tend to be huge!
Im talking 16-22 cubed for a pair of 18s after displacement and tune low with massive port area 14-16sq inches per cube.
I only toss a little under rms of my woofers, but Ive gave more then rated rms in the past. The one thing Ive noticed time and time again is knowing your setup...
If you get your woofers a bit hot and stinky dont shut them off, but keep them moving at a moderate volume to keep air moving around the coil.
Proper set amplifiers is also a key essential.
Generally smaller boxes will take lots of added power (over rms ratings) and also can get loud if all your after is a burp number.
I used to make the box as big as I could the woofer cause it sounded good on a lil bit of power...but after reading about different effects according to box size, i became a bit more concerned because i tend to overpower subs....
So I have 2 btl 18s and I'm thinking 18 cubes for both tuned to 33hz on 1 crescendo 3k sound good??
2 18" fi btls
2 sprinter batts 165ah
1 cresenscdo 3k
1 mechman 270a
1 kinetik 2000 under hood
  • Who's Online   0 Members, 0 Anonymous, 1830 Guests (See full list)
