So they manufactured this new 100 percent tailpipe free vehicle that is suppose to improve emissions and it doesn't use any gas. But as I was scoping out the new car I couldn't help but wonder; Could you put a decent size audio system in this without it dieing. My guess would be you could although the distance you travel would lower significantly. What you guys think. :popcorn:
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
The way I see it is that the car is probably packed with Li batteries and I have heard that they can't cope with a real system with todays technology. So I would assume no. Also, that much extra weight on an electric engine would shorten the range considerably and then having to recharge the batteries.....
Basically no.
what you gonna do when you travel, it take more than 100 miles to go from state to state and the charging dock is in your garage. i think 68 at 55mph with luggage.
Mechman 320A
OEM AGM
its not made for highway driving more like meter maid type stuff .its just a high speed golf cart.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Does anyone know the specifics on the batteries?
Never mind.. here it is
mechanical
motor + battery
* 8o kW AC synchronous motor
* 24 kWh lithium-ion battery
* 3.3 kW onboard charger
* 120 V portable trickle charging cable3
Edited by Hotdog
I guess its an start to something bigger. Be cool to add an alt to it
Mechman 320A
OEM AGM
They supposedly are going to have charging stations that can do a recharge and it gets you like 68% charge in 2 minutes or something. It's not made for traveling long distances
a 4cyl diesel motor is alot more logical than ANYTHING electric. only electric car i want is when i pull the IC engine out of it. only decent electric car is the tesla and it still sucks.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
