you can never go wrong with 4ga wire !! i only have a 400watt rms and 300watt rms amp and i still run 4ga ... never hurts and never have a problem with voltage drop or heat
He probably knows what they are for, which is why he has them. But I'm onboard with the wire size. I've melted and started many fires with wrong sized wiring.
2012 Honda Accord
Radio: Pioneer AVH-4200NEX
Ditch the caps. Seriously, they don't help your electrical system !
Just do the big3 in ...4 awg(if it's what you got).
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
A lot of people would agree with you, and a lot would disagree. Capacitors with no charge pull more current than the amp alone would, BUT not when they maintain a charge, like if the car is driven everyday. It's obvious in theory and in practice that having a stiffening capacitor will prevent minor electrical issues. I'm not gonna put the time for that into my girl's car just to fix headlights dimming. In my own car, caps immediately improved my bass response too. Better yet, they're cheap.
Edited by osamio
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
B) I like what he said... sort of...
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
the longest run burnt up because it has more resistance. the shorter runs (cap to amp) can handle a lot more current because they are shorter, less resistance.
no go put some proper fuses on that power wire before you burn your car down. upgrade it too. obviously 8awg isnt enough, and it hardly ever is.
Keep in mind wire has the same resistance per unit length no matter what the total length is. So trying to push say, 100 amps through 8 gauge will heat up the same in each section no matter if it is 1 foot or 20 feet. (sortof) The main reason you need bigger wire for a longer length is because there will be more voltage drop. (which could cause more current draw causing more heat)
New wiring held up. problem solved. thanks for the input.
2009 Cobalt LT
Pioneer Headunit
4x Pioneer 6 1/2
Pioneer GM-6400F
To come:
umm.... no. I think you need to go on BCAE1.com and read up on the "wire" section. what you said would be like if you lined up ten 1lbs weights and pushed them, somehow it would be as easy as pushing one of the 1lbs weights.
  • Who's Online   0 Members, 0 Anonymous, 550 Guests (See full list)
