As the title suggests: What are the pros and cons of a bigger / smaller sub box? I know that in a ported box, bigger = more effecient, but smaller = more power before reaching excursion limits.
Does the still apply to sealed boxes? Will it affect frequency roll off in any way?
And one more question: Even though a sub may not be recommended for a sealed box, could I still do it? I like the tight feel of a sealed box more, but my favorite sub that I have in my current box is only recommended for a ported box.
I would go with a ported box, plus the sub says to do so. And it's good to have a big ported box but don't go too big or else your sub will sound like ass. And yes you could put it in a sealed box but it will shorten the life of your sub
Sub: 15" Asendant Audio Mayhem
Sub Amp: Audioque 2200d
Headunit: Alpine iDA-X305
Speakers: Rockford Fosgate Punch 6.5's & 6x9's
Speaker Amp: Rockford Fosgate Prime 300.4
Wiring: Knukonceptz Kollossus Fleks 0 Gauge(sub)
Knukonceptz Kollossus Fleks 4 Gauge (speakers)
Battery: Optima Yellow Top
Alternator: 165 Amp High Output
the size of the box mostly plats with the pressure inside the box. small box = more pressure. the pressure is a part of the speakers suspension. thats why you can put more power to a sub in a smaller box. subs designed for ported boxes already have a stiff suspension and dont perform well in sealed boxes. while subs that can work well in sealed boxes have very loose suspension.
you could go with a small ported box tuned to about 32hz and still get a nice punchy sound.
I understood it to be the other way around on the suspension, stiffer for sealed and not as stiff for ported.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
only time i would build a smaller box is if i'm running more power to my subs than they're used to handling (do that with a bigger box and it'll blow sooner)
its not that itll blow, itll tear itself apart. if the coil goes out in a large box its more likely that the coil slammed into the bottom plate hard enough to bend something.
skullz - im going off of my logic for that one, not fact. im pretty sure its correct but i could easily be wrong.
How about for efficiency's sake? Lets just assume same sub, same power to the speaker, etc... Would a smaller or louder box get louder? Would a different size box affect high / low frequency response?
Again, assuming it is a sealed box. I know about it with ported, but not with sealed.
Playing with port area and tuning can also allow you to run more than rated power in a larger box without have mechanical problems i.e. Bottoming out...
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Only variable being the sealed enclosure size, the larger box would have a lower F3 than the smaller one.
My YouTube Videos
  • Who's Online   0 Members, 0 Anonymous, 1468 Guests (See full list)
