So I just got a new amp for my 2004 Tahoe, this is my first install for this car and was going to mount the amp under the rear seats. My only problem is I really don't want to screw into the floorboard.
I've seen people say to glue a piece of wood under the carpet and then drill into that, but I can't get anything under the carpet without having to pull out the seats entirely.
What I was going to do was get a piece of 2x4 or something similar and put it on each end for the amp to be screwed into, and use velcro on the bottom side of the wood to keep it in place. I wanted to know if this would work fine or would there be too much vibration by only using velcro.
Here is a few pics of under my seat: http://imgur.com/a/2UTZY
The reason I was going to use 2x4s was so I could get over the bar in the middle of the photo and then be able to have ventilation under the amp.
So would this be fine to use velcro to secure the wood in place or will it be too loose?
Why not just pull the seat it seems daunting but its not that bad
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
Or you can get some brackets from your local hardware store and use the bolts securing the seats to mount the brackets to and mount the brackets to the piece of wood you're using to mount the amp....
most amps generate heat through the fins, which are usually on top and sides...So no need to space the bottom. If anything, you'd want to mount it as close to the floor as possible so it has space to "vent" out the top. I'd probably just take the seat out; would look cleaner that way.
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Not gonna lie... I've used industrial strength Velcro for mounting amps many, many times. That shit is awesome. But all of my installs are permanently temporary. If I was doing a "daily" install... I would look to something more secure.
I'll parrot the advice above. Use the seat bolts.
Unsecured items in a car become projectiles when you crash. I would not trust Velcro.
Pioneer 80PRS
I won't lie I have used velcro before make sure it's industrial and use alot not the best way to go best would b bite the bullet and pull the seat make a amp rack. Cause amp could become a projectile
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
I have used industrial strength velcro for years. I had a 12 inch Type R in a huge ported box and it was only secured by velcro. I would go off roading and the thing never moved. It is cheap also. You can get it in large strips or pre-cut pieces in the fabric section at Wal-Mart.
  • Who's Online   0 Members, 0 Anonymous, 1652 Guests (See full list)
