Imnot impressed with the warhorse at all i have 2 teamates with them and there numbers arent spectacular. show me someone putting up 55s with a warhorse. op what are your numbers i would d0 4 sd 3500s all day over 2 warhorses. they only do 10k at 14.4v and like 6k at 12.6 from the research ive done
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
its his electircal did you look at the minimum requirements for the warhorse? it says u need 2 200 amp alts and i think 8-10 800cca batteries. so you should have a quad alternator setup and like 8 -10 xsd3100 to be getting good power Steve has 30 000 watts and he has 4 alternators and 10 batteries and his voltage is good
bottom line kicker makes good products and theres nothing wrong with them and theres nothing wrong with sundown but, if u want to compare the 2 atleast follow the requirements then compare
your guys's logic sucks. jacob could fit his dick in a beer bottle with how wet it is from people sucking it.
i bet its impedance rise. less amps=more rise.
you had less rise when you had more amps, thus making more power. plus when you had 2 HUGE amps, your electrical probably couldn't handle it.
You don't think Rusty and DC is the sameway?!
I bet if the title said 4 DC 3.5ks, people would of said the same thing or maybe even bashed Kicker more.
Seems nothing is comparable to DC on this site.
Also, people saying their no impressed with the warhorse, I don't get why not.
Who cares of nobody is doing big numbers with them. Nobody big is running them to do it. When it comes to SPL and 160+dB is +90% install. Equipment is only a little factor. Granted the Warhorse does the power, it will put up the way numbers of a amp that is equal to it in power. As I'm saying, in theory 10k watts vs 10k watts, will be the same.
But testing two different amps will yield different results because of varies variables. But that's another topic.
Still, 20krms(rated) vs 14krms(rated). The Kicker should be louder in the end. Depends on variables of course.
We don't even know if he wired it correctly.( don't wire below 2 ohm.)
More powerfull amps on the same electrical means most of the time lower wattage, because of more voltage drop.
People saying Sundown over warhorse are just full of nonsense.
You guys really think a saz 3500 will put out 5000watts? ><
Because the warhorse will put out atleast 10kw of power.
To the OP, you need better electrical.
You switched from 14kw to 20kw atleast so you should upgrade.(although a warhorse is very effficient.)
Each one draws 900amps
Kicker makes good stuff but its not really worth it trying to get 10k out of a warhorse
I have to disagree when it comes to 160+ installs where the equipment doesn't matter. I want to see a 160+ install with pyle, boss, and soundstorm...
And maybe theres a reason why nobody "big" doesn't use the warhorse.
I lol'd because this is so true.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Haha same here. I see it all the time.
:werd_msword:
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
I think he meant something along the lines of throwing together two BTL 18's with 5k running them and hitting 50's. Anyone can do that, but not alot of people have what it takes to turn that into a 155. Just an example.
  • Who's Online   0 Members, 0 Anonymous, 6888 Guests (See full list)
