So I went to the shop yesterday to finally get my wheels put on the suburban 26x9.5Dip Libra 15 on Lexani LX9100 tires. Well the tires are 305/30/26 and they rub up in the front really bad. The shop recommend that I go to a smaller tire or that my shocks and springs may need to be adjusted or change. They said that this was the first time that they couldn't get this setup on my style of truck with the 305 tires. The truck has around 94K miles on it and I've never changed the shocks or struts on it, should I go that route or should I go with smaller tires like a 275? I kinda don't want to go the smaller tire route cause the roads here are really bad and I don't want to fuck up the wheels when going over a shitty pot hole?
2007 Chevy Suburban LT1
Pioneer AVH 5700 DVD
Diamond Audio D3 6 1/2 components
Kicker 06ZX650.4 amp
Kicker 06ZX2500.1 (x 2)
DC Sound Lab Level 4 18's with Level 5 coils
Autotek Mean Machine 400.1D (replaced)
Soon to come:
rims
body kit
flow master pipes
Confuscious say "he who say it can't be done shouldn't be bothering man busy doing it"
Now feel free to go crawl back under that rock and leave this to the professionals....
big hammer and trimming under the fenders will help
unless you have a 4wd then you can turn tbars up little
Edited by wenn_du_weinst
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
Wenn,
Its a 4x4 truck. I don't want to do any cutting at all if I don't absolutely have to. I was thinking of taking a heat gun to the inner fender covers and seeing if I can reform them.
Soon to come:
rims
body kit
flow master pipes
sometimes all u need to cut is the inner liners on both sides, maybe the inner corner of the front bumpers, usually not really noticeable
got any pics?
if you dont want to cut then try to get smaller tires=shtty roads= :( alittle trimming=nice tire size= you-> :yahoo:
crank on your torsion bars a little bit or add ford/similar keys to lift up the front.
Shouldnt be too hard to get little lift.
Edited by Sir-Lancelot
2001 Yukon XL
Sitting on 35 x 12.50 x 20, XD Monsters
Headunit: Clarion DXZ785USB
Front: B&C 10NW64 10" Neodymium Woofer, Crescendo XST2
Rear: B&C 8NDL51 8" Neodymium Woofer, Crescendo XST2
Mids & Highs Amps: MB Quart DSC 4125, MB Quart DSC 480
Subs: 4 18" SSA ZCONS
Sub Amps: 4 GP3K Pro
Electrical: Iraggi 260a, 3 tejcurrent 240a, tejcurrent quad bracket
Kinetik - 6 HC2400
My Build Log
Whats the offset of the rims? could be possible that its too high
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
I forgot what the offset was on the wheels I'll find out tomorrow when I call the shop. So you guys think just an adjustment on the torsion bars will do the trick?
Soon to come:
rims
body kit
flow master pipes
The wheels have a +10 offset.
Soon to come:
rims
body kit
flow master pipes
i have 295/25/26 on mine.......for you i would probably suggest a 295/30/26. I dont know that i would do a 305 on a 9.5", 26. Seems kinda wide for a that rim IMO.
I would also suggest you use Pirelli P-Zero like mine. You will love them!
good luck! :drinks:
Follow my Tweet (Twitter)
