allright I got a customer that is looking todo a real nice SQ system in a 2005 Ford F250 4 door truck.
from what I have seen of the truck there is no space for sub/subz
under the rear seat of the truck he has a memphis belle 5 channel amp its freaking HUGE it goes from door to door.
basicly the area under the rear seat is pretty much out of the question.
he is open to suggestions but told me WE cannot cut the truck so a blow through is outa the question, so the only thing I could come up with was either A under the Dash or a center console enclosure, either way it has to be a shallow mount sub because their is just no room, and to be honest I havent ever heard a SQish shallow mount sub.
so If you have ever done a install/build in one of these trucks I need to pick your brain ;)
thanks in advance
David
here is a shallow mount by TC...im sure its hella expensive...also, tangband makes a shallow mount
http://www.audiopulse.com/products/passive-radiators/vmp/
edit: sorry, thats a passive radiator
edit again: here is that tangband sub
http://www.partsexpress.com/pe/pshowdetl.c...tnumber=264-862
Edited by amatt85
i likes me some audio stuff...
Subs in the rear doors.
1 or 2-8's per side.
I did a 2000ish Dokdge Dakota Quad cab and same scenario-ZERO room under seats and no willingness to mod the truck.
I glassed the door panels and built out right to where the rear seat starts and up to the backs of the front seat.
I managed .75cft on each side and was gonna run an audiobahnn 1000watt 10" sub in each door.
The pods stuck out QUITE a bit but it was all glassed worked quite well IMO.
I can post some pics if need be for a better idea of what I'm talkin bout.
Rear doors, 4-8's and call it a day.
~2cents.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
David,
I will definatley be interested to see what you come up with. I am in the same situation. I really want to do an SQ setup in my truck, but being that I trade out vehicles every 3 years, I absolutely cannot cut the truck up and screw it's resell value up.
I have been looking at different setups since I got my current truck and I can say that the trucks nowadays have absolutely no extra space at all...which sucks.
Here's a couple of thoughts that I have been working with on my truck.
1) behind my backseat there is about 4 inches of foam and insulation. So I could easily cut out some of that material and mount some amps back there. The issue that I have is finding an amp that has a side mount fan to keep air flowing through it.
2) Can you put some square tubbing under the mounts on the back seat and raise it up to give you more space underneaath. With my truck this is doable, but it makes the seatbelts inoperable, so I have to rig something up to make them work.
One other item that you might want to look into is the electrical system. I was working with some mechanics that I know and another issue with my truck is that the alternator has a signal wire going to the ecm..where as aftermarket alternators do not. So if I replace my alternator with a non oem unit, i get a check engine light. So I am forced to put in multiple alternators and have a stage of batteries, in which I again don't have room for...lol
I'm tempted to just go buy a civic to have as a beater for tunes..lmao :mad:
Edited by str86diesel
2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
had a buddy who did this in his f150 down fired the sub in an extended rear center console type setup. the amp cant go behind the back seat?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
The factory sub location is 1- 8" in a box behind the driver side, under the seat. What my boss and I did, we came up with a really small sealed enclosure for 2- 10s, and it worked great. It was musical, not to boomy , but great for rock, techno, ect. But the cone area helped with the lows 2-10s in a 0.8cf spot
These are the subs we used.
http://www.lorentz-audio.com/Merchant2/mer...t_Code=LRW-SL10
i have a friend who has a 4 door Harley Davidson editon f150 and he gutted the center console, made a box in it and put a p3 shallow mount, and then did the same for the back. Went to a junkyard abd bought a center counsole and glassed on it.
Hes got it downfiring, and a port near the bottom on both...
Sounds really good
Edited by pink_floyd
Lets Go Ski
  • Who's Online   0 Members, 0 Anonymous, 1170 Guests (See full list)
