I have had to re-do my sound system after selling my sedan and buying a Ford Courier truck. The old sub and box was too big so now I am looking to get 2 Image Dynamics ID10 V.3 D2 and integrate them into the rear bench seat.
The stats on these subs are as follows:
Recommended RMS Power: 100-300W
Peak Power Handling: 400W
Impedance: dual 2 ohms
They are DVC's
Now would I be better off buying one mono amp such as a Kicker ZX750.1 (750Watts) and wiring them up so each sub gets around 320Watts each? (If that's even possible), or should I look into buying 2 smaller mono amps and giving each sub it's own amp, OR, just buy a 2 channel sub and give each sub it's own channel?
Any help would be much appreciated!!
Cheers,
Sac
Buy the 750 kicker , the kicker amp will put out over 750 tho so be careful , you may also get away with just a 500.1 , I have never herd of subs with a 100 watts differince I'n rms from norm to peek it's usually 2x the norm
This. I'd do a 500.1 just to be safe. And even then might be pushing it
2011 Honda CR-Z Mugen
12" Kicker SoloX Subwoofer
Rockford Fosgate t20001bd
Pioneer AVIC-X930BT Head Unit
Build Log
With one amp you would have to run them at 2ohms or .5ohms. If the amp is 1ohm stable then run it at 2ohms. Check the rating at 2ohms and more than likely it should get it within the power range for those subs.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
The 500.1 is great, that's what I am getting for my 2 10's. Also here is a link on how to run those subs to it.
Here!
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
the12volt.com is what i use for my wiring, its good up to 4 subs i think? i dont fee like checking lol its good unless you have a odd coil config, like 1.4ohms, .7ohms etc
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Here!
So using that diagram, the amp would put out 500W and how much would each sub receive? Do they get half each?
Yup.
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
i wouldnt do the kicker. I would check out Rockford R500-1, or ebay the American Bass SQ1150m. Ebay says it does 700 rms, but i've owned it and the manual says it does 350 @ 1 ohm. And its a stupid cheap price.
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
  • Who's Online   1 Member, 0 Anonymous, 1245 Guests (See full list)
