Sealing outside edges of enclosure..
The search wasn't working for me so i apologize if this topic has been discussed in the past..
I recently noticed on the outside of the box, mainly where the baffles meet there is a small leak..i can feel a little bit of air seeping out. The rest of the box seems to be fine. What is something i could use on the outside seams to seal them up nicely? Also, what is a good way to make the subs air tight(where the sub is mounted to the box)?
2004 Explorer Limited
24" Lexani "pyros" wrapped in 255/30/24 pirelli's
270 Amp MechMan Alt.
(2)Stinger SPP-2150's
(2)Sundown NightShade 15's
IA 40.1
number 1 would be the gasket that come with subs to seal any air leak from the sub cutout or weather stripping, if there is a little gap on one of the sides, just put some caulk or silicon along the inside edge and let it dry and you will be good to go.
Silicon works fine for sealing a small leak. And as for sealing the subwoofer, duct tape has been proven effective lol...
ELMER'S WOOD FILLER. Comes in a small tub. I live by this shit when making boxes. Dries hard and fast, sands nice and smooth. You'd never know there was seems on your box in the first place.
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
I would say, make the inside completely sealed and you wont get any air escaping throught he baffle. I also have a question to about my subs, There are a bit of smal leaks where the screwed screw in and holes through the mounting hole. Any way to fix this, with being able to remove the subs and not damage stuff?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
X 3 on the wood filler and wood glue! All my corners in the box I'm making right now are sealed with liquid nails and a coat of wood glue over it and tomorrow I'm do the filler! But if I had a leak outside like you I'd probably fill the gap with wood glue, it dries hard and the put wood filler over it
and as for the subs, I saw this video on YouTube of Exo, he got some rope caulk (weather stripping but it comes in a roll and it's like a putty) and he wrapped in around the underside of the sub where it mounts, not too much just like 2 strands. And he said he would never install a sub without it after trying it. I got some to try out.
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Wood Filler? Make your own wood filler!
Get some of that good yellow wood glue - then collect a cup full of saw dust ( the shredded good saw dust not the clumps )
Mix the two. Smear it on with your finger - Sand it smooth. Blends right in.
Cheap - Recycling of sawdust!
1/0 Power Wire All Around + Big 3 - $140
Rockford Fosgate T2500-1BD - MSRP $1800
(4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200
XS D6500 $245.65
PIONEER AVH-P5200DVD 7" Head Unit = $430
Soundstream SC-6T Component 6.5" FRONT $60
Pioneer TS-A1673R 6.5" REAR $85
A Bangin system! = PRICELESS!
this is what I did to fill some screw holes... then couldn't be bothered waiting for it to dry, messed it all up using the router :pardon:
It works :shrug:
XS D6500 $245.65
  • Who's Online   0 Members, 0 Anonymous, 1591 Guests (See full list)
