IH8PunkRok Posted August 11, 2011 Report Posted August 11, 2011 you know i think the fuse holder is backwards.. the output side should be split not the input. you see for example one fuse blows and all it does is take out one input cable. whatever is connected to the output side is still going to get power, the load is just going to be spread over the other fuses unless the top is input and the bottom is output... either way solid bar should be input, broken bar should be output. but Ric i am sure you were aware of this i just had to talk it out to have it make sense the amp rack is looking good -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
727Designs Posted August 11, 2011 Report Posted August 11, 2011 unless the top is input and the bottom is output... That's my guess. -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
sayhuh? Posted August 11, 2011 Report Posted August 11, 2011 you know i think the fuse holder is backwards.. the output side should be split not the input. you see for example one fuse blows and all it does is take out one input cable. whatever is connected to the output side is still going to get power, the load is just going to be spread over the other fuses unless the top is input and the bottom is output... either way solid bar should be input, broken bar should be output. but Ric i am sure you were aware of this i just had to talk it out to have it make sense the amp rack is looking good Huh? First, you cannot tell which side is input or outpit without wiring lol. Therefore, the fuse holder isn't backwards or forwards, right? Also, I'm trying to look at what you are saying and can't make sense of it. Wouldn't you won't each cable to be separated before the fuse, this way if one cable has an 'issue' then it will only pop that fuse. Wiring like you said with the solid bus bar would mean if one cable caused a spike, then it would go thru the buss bar and take the path of least resistance, causing more than one fuse to go rather than just the cable with a problem. Or am I thinking bass ackwards? lol Blown
IH8PunkRok Posted August 11, 2011 Report Posted August 11, 2011 it seems to me you are thinking backwards but you are correct that we cannot tell which side is input or output without wiring. so ill shut up and just let it happen lol -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Bigballa39213 Posted August 11, 2011 Report Posted August 11, 2011 Just Amazing 98 Chevy Blazer 4 Door Stock Everything The New Setup 1 - Pioneer AVH-P5200DVD 1- Pioneer DEH-80PRS 2 - Blues Audio 5.25 Mids ( On the dash ) 2 - Blues Audio BL8.0C Components ( In the front doors ) 2 - Blues Audio BL8.0 Woofers ( In the rear doors ) 1 - Linear Power 952 ( Dash ) 1 - Linear Power 2202IQ Modified ( Components ) 1 - Linear Power 3002 ( Rear Doors ) 1 - SoundStream XBP-10 Processor 1 - SoundStream BX-20Z 2 - SoundStream DTR1.3400D 4 - RE Audio SX12D4
cgrez33 Posted August 15, 2011 Report Posted August 15, 2011 That just looks sexy. Current Build: 1999 Tahoe #ComingSoon Previous Build(s): Crossfire Magnum 5k Pontiac G6 GT
Ric Thornton Posted August 16, 2011 Author Report Posted August 16, 2011 and there will be more lighting...
MrSkippyJ Posted August 16, 2011 Report Posted August 16, 2011 Just...wow...can't think of anything else. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
C-Fizzy Posted August 16, 2011 Report Posted August 16, 2011 I like it, ric. Good job. under construction I hate People with crappy primered cars rolling on hubcaps that are louder then me. u hate c-fizzy?
