I have 2 Kicker DX 1000.1 mono amps on 2 deep cycle batteries from a 250 amp altenator. There are no problems with the wiring coating or grounding out. One problem is the wireing is undersized. Two amps should probably have a 1/0 gauge wire. The wire was heating up but never got excesivly warm. Was there not enough power draw, because I thought fuses blow when there was too much power draw? Both amps are 1 ohm stable and are wired to 1 ohm with 2 subs a peice.
Wire digram
Deep cycle---4 gauge---distribution block-- two four gauge wires split to 2 dx's grounding is 4 gauge and less than 2 feet.
The same amp always blows the fuse on the distibution block (at rating 100 amp fuse) the other amp is using an 80 amp fuse on the distibution block and has yet to blow it. The amp that is blowing the fuse has a longer 4 gauge from the distribution block, 3 ft as apposed to 1 ft on the other amp.
My question is what would cause repeated fuse blowing? The amperage draw is hard and does pull the truck below the 14 mark (around 12 or 11) Would upgrading to a 0gauge wire from battery to distibution block solve this problem? I unhooked the amp that never blows and just ran the amp that does, and the amp never shut off, or popped a fuse. The problem only persists when both amps are hooked up not when the are running solo.
Edited by thatkickerguy
1/0 or 2ga should be used from the batt to the d-block for sure. I'm not saying that is what the problem is, but 4ga cannot deliver the amperage that your amps need to run right.
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
your amps are not one ohm stable.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
K so I'm not a huge kicker fan, but that was the first thing that came into my mind, then he said "both amps are 1ohm stable" so I was like hmm, maybe some kicker 1ks are 1ohm stable? Lol....
But yeah op.... There is your problem...but yeah put your 1/0awg in there anyways man
so far...
^^Truf.
http://www.kicker.com/sites/default/files/2008%20ZX%201000%201500%202500-1%20e01%20web.pdf
^^lies
^^Truf.
http://www.kicker.com/sites/default/files/2011%20DX%20Mono%20Amps%20RevI.pdf
Google failed me. Then I failed me. :weep:
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Actually he has the DX series witch are 1ohm stable.. Forgot about them. The Zx arent.
DX Series Monoblock Class D Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 280 watts x 1 chan.
2 ohms: 550 watts x 1 chan.
1 ohm: 1000 watts x 1 chan.
Edited by DudeWith4x4
-Ross
Project Layla
Truck: 99' F-150
Gathering things for my next build.
SoloX18 build:
http://www.stevemead..._1#entry1576460
RE T-line build:
http://www.stevemead...-between-build/
http://www.kicker.com/dx_amplifiers
kicker does not make 1 ohm stable amps/.
either ethat or their own website is wrong
MODEL [at 14.4V]: DX1000.1
POWER [watts], CLASS D 2 OHM MONO: 1000
REMOTE BASS INCLUDED: yes
REMOTE BASS CAPABLE: N/A
DIMENSIONS [in, cm]:
[all models 2-1/4H x 8-5/16W x ... L] 10-1/4"
[all models 5.7H x 21.1W x ... L] 26cm
COMMON TO ALL MODELS
FREQUENCY RESPONSE [Hz]: 25-200, +0/-1dB
INPUT SENSITIVITY: high level 250mV-10V, low level 125mV-5V
SIGNAL-TO-NOISE RATIO: >95dB, a-weighted, re: rated power
ACTIVE CROSSOVER: 18dB/octave, variable 50-200Hz, low pass
only [DX250.1 24dB/octave, fixed @ 80Hz]
SUBSONIC FILTER: - 18dB/octave high-pass variable 10-30Hz
[DX250.1 24dB/octave high-pass fixed @ 25Hz]
KickEQ™ BOOST: variable to +12dB [DX250.1 selectable 0 or +9dB], centered @ 40Hz
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Kicker did make amps that are 1 ohm stable.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Well I took that right from their site. Everywhere else does say 1 ohm though. :pardon:
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
