DC Sound Lab
On the website, it says 9 1/4" mounting hole diameter. The sub doesn't fit, not even close. I slowly and carefully went around with my jigsaw to increase to 9 3/8". Still doesn't fit. Do the newer 10's have bigger baskets or something? My baffle is only 9.5", so I can't go much bigger. Might have to do rings again.
SMD Super Seller
My Feedback Thread
same problem with my 10's as well i think its a typo on the website
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
just measure the outer diameter of the sub and the width of the gasket then subtract 2x the gasket from the overall
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
Measure the inside diameter of the gasket and that should give you close to the right size
I just did that. The issue is the diameter is a tad bigger than the height of the baffle. I can fix it, but its gonna be a pain in the ass if I end up having to cut into the top and bottom pieces of the box. Website specs need to be fixed.
SMD Super Seller
My Feedback Thread
Would have been good to know before designing and building a box. How big a hole did you need o make them fit Knockin?
i honestly dont remeber i just got mad and starting cutting with a sawzall all i had atm until it did fit but ill check right now subs are out since im doing sumthing else to the mustang gimme a sec..and i know the basket was the issue of not fitting
CAR
H/U
Amps
Subs
4 AQ HDC'4s 12's
Mids and highs
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
  • Who's Online   1 Member, 0 Anonymous, 5035 Guests (See full list)
