I went to start my car today and all that I got was a single click and then there was nothing, not even power. At first I thought my battery was dead. I hooked up my multimeter and every thing was good. I even have power when the key is turned to auxiliary. Every thing was working fin yesterday. What could the problem be?
The vehicle is a 2002 Mazda Protege Lx 2.0L
Click Links To View Build Logs
1994 - Mazda B3000 (Daily/Toy/Show)
2002 - Mazda Protege (Daily)
1995 - Hyundai Accent (R.I.P.)
1984 - Bronco II (Restoration Project)
Youtube Channel
could be your starter. i had the same exact problem when mine went out.
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
That's what I was thinking :(. I just spent $320 on the lower control arm... Any way of testing it?
Youtube Channel
Take a wrench and tap your starter kind of hard a few times... If it starts after you do that, it's a bad starter.
Also Sounds like it could be a bad ignition module.
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
could be a bad starter solenoid as well. if you tap the starter with a hammer or wrench and that doesnt fix it then put a screwdriver between the battery positive on the solenoid and the trigger terminal and see if the car starts
1999 Audi A4 1.8T:::
4 - DC Level 3 10's in a 4th order
Rockford P6002 on Subs for now (3-3.5k coming eventually)
MB Quart ONX4.60 for Mids and Highs
Boston S50 Components in Front
Boston S65 Coaxials in Rear
40 Sq Ft of Second Skin Damplifier
Build Thread
UBL
1948 Plymouth
What you could do to see if your solenoid is engaging or not would be to remove your starter from your engine and then connect the solenoid of your starter to the positive of your battery, and then to ground the starter just connect the case of the starter to your batteries negative. It should make the gear come up and then release back when you no longer apply power to the solenoid.
It more than likely is just a bad starter, they typically go without any warning. If its just a stuck solenoid tapping on the starter with a wrench, 2x4, anything somewhat long to get into where your starter is but though enough to put some force on the starter can sometimes get it to engage. If your starter solenoid is engaging but the gear wont spin, you usually cant fix that other than to buy a new starter.
If you want to play it safe take the starter off and tape off the positive wires in the time it is off to prevent a short out. You can take the current one to autozone, advance auto, etc for testing. They can test them in the store for free if you want them to verify if it is dead or not.
Ok so I randomly went to try and start my car and... it did! WTF is up with that? It smelt a little like gas once it did start, I'm guessing it got flooded? How..? I do not know but all well it runs good now and starts ok. Tomorrow I'm going to replace the fuel filter and do an oil change. Hopefully that makes thing a little better.
Edited by C.Sanchez.A
Youtube Channel
How long did you try to start it for before you quit and walked away? Did you give it any time to rest between starting the car and not getting it to actually kick over? When you couldnt start it, did you hear the clicking noise or the engine actually turning over just not getting a spark?
If you just flooded the engine you would smell the gas at a very strong smell and the car would eventually (like 5 minutes) start back up but seem to mis fire until it burns out all that excess fuel that was dumped into the engine. Also even if the engine flooded your engine would still turn and you could hear the starter working like normal but it wouldnt "catch" or get a kick from the fuel combusting in the engine.
agreed. i would venture to say its the starter selenoid. most vehicles the selenoid will actually keep all the compents of the car from cutting on. and as well it can be a hit and miss with the contacts which explains why it started one time and didnt start the next. i would replace the 5 $ selenoid just for good measure.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
It also could be that the battery is bad, the voltage could be correct, but the amperage could be down which means your starter isn't getting the right burst of current. If you can get someone to come by and try to jump start it, and it starts, it's most likely that the cold cranking amps are down too low.
  • Who's Online   1 Member, 0 Anonymous, 1644 Guests (See full list)
