XS Power
This is an entire new design of battery. There is a huge market for high capacity secondary/supplemental power batteries and this is the answer. Great for Marine and the car audio customers that need to add capacity for a lower price. More info the closer to SEMA we get.
awesome, so they are for like rear batteries, or ones that will be away from heat
Yes, they are not designed for being under the hood in a cranking application. Only designed for supplemental power with high capacity in mind.
can i still keep the orginal battery and use the xp series batterys in the back and be fine? for example i have a d3400 under there now can i still keep it there and have like 6 of those xp batts in the back and be fine?
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Sweeeet 30 to 40 bucks cheaper with more reserve capacity....i want 5 lol
Had an estimate of 6400 for an alpine/clarion setup dealer said it "should" hit around 160db with the custom boxes he was going to make for me..doubtful with so much area to move but, budget is way below that :( any ideas on cheaper brands for that kind of Spl setup? really didnt want to try any Boss or soundstorm, thinking Quantum figure around $150 per speaker "$1800 total" and $1700 to power it, first actual big setup for the van.
New MEMPHIS CAR AUDIO build
4 15s Memphis C3
2 xs power D3100
1 xs power d3400
custom fiberglass door pannel
and lots more
My Build
X2 are these new batts lighter I have 4 3100s in my trunk car and shiz is saggin lol
Edited by deepsilencer
TEAM FLEX ISSUES,TEAM DC AUDIO
2000 Silverado Ext 1500 v.3
(Walled Silverado)
4 DC Power 270a Alts on A DC Power Quad Alt Bracket
XS Power VCM,Stinger Volt Meters
4 AA Mayhem 18s
2 DC Audio 9.0ks Strapped
1 DC Audio 175.4
4 Selenium 6.5s & 4 Selenium 8s
4 Selenium Super Tweeter st350s
72 SQ Ft Of Stinger Roadkill Expert
Alpine CDA 9887
XS Power d3400(Hood),6 XS Power d3100s(Bed)
& much more.....
2011 Meca CA State Champion & State Record Holder In M5
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
BUILD LOG.....YOUTUBE CHANNEL.....FEEDBACK
Can you mix them up? Like I have some 3100's in the back now would I be able to add some of the new ones to them with out any problems?
01 2dr ExploderBuild log2 18" DC Level 6's (M3's)DC 10k5 XS d3100's, DC 390 alt100' shok ofc cable
Team ShokTEAM SUB SONIC ADDICTION
I believe u can,same chemistry as the old models
Just that these can't be in heat,that's all
(Walled Silverado)
4 AA Mayhem 18s
1 DC Audio 175.4
Alpine CDA 9887
& much more.....
Meca SPL:158.2
Meca P&P:137.4
DB Drag:159.1
USACI:161.2
This is marine related ;)
I'll be honest, I've never once thought about swapping out any of the batteries in my boat (bank of 4) for AGM. The main reason being that most of us isolate a battery when we are sitting around out in a cove or whatever partying it up (running TV, stereo, fridge, sat receiver, gps, ship to shore, etc) and run the batteries down to nothing on a regular basis. They are however always on a charger when docked (obviously I would need to switch chargers as well). Is this the kind of abuse you have designed them to take?
I know doing this isn't technicall "good" for them, but that is what you do on a boat (most marine batteries are made with that in mind) and the current batts on the boat are around 6 years old and are still fine (they will need to be replaced soon I'm sure). I just want to be sure that this is really what you have designed them for. Also I would assume that while you don't want these under a hood, them being a foot away from 2 350's that are water cooled isn't an issue (the batts are near the motor(s) on most boats).
Edited by UnderLoK
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
