put your wrench on the pulley bolt and it will untension as you try to twist the bolt. I believe you need to loosed the bolt to make that work, if that doesn't work then reverse you direction.
edit ---- orion fucking :ninja:
Edited by captainhook426
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
Not really sure on the second part, I tried turning it and daaaaamn, it ain't budging, maybe I either need more leverage, or it does hold it in place.
It might be seized up. Aka bad tensioner
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I have a special tensioner wrench in my box that is like 2' long of so. some of them are just have to turn.
Well I could get the tensioner to move some, just not near enough, so I thought, maybe I can take some of the tension off with this think that says load on it.
Put the socket on the pulley part of the tensioner it will give you enough leverage to move the tensioner
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
And I don't have anything with me long enough(over 10") to get a lot of tension on it, I usually see my dad when he does his or anything that needs a lot of tension putting a pipe over the side of the wrench to extend it.
Since you do not have a tensioner tool u might try this. Get a piece of metal pipe that will fit over the handle of your ratchet. Place socket on the bolt on the pully and turn away from the belt. The tensioner is probably just stiff and hard to turn. It could be seized like n8 said if so it will break the inside apart and never regain tension. If that happens go to parts store buy new one. Then you will need to loosen the top bolt to take it off and replace it. The top bolt should not need to be loosened to just release pressure on the belt.
Barstad
