whats better solid wire or wire with more strans
couldn't you buy an insulated tube to put it in like the ones you run electricty through the ground with?
I assume you could, but again, solid 1/0 practically requires a pipe bender to get it around corners. It just isn't practical to run it long distances through the interior of a car. I was trying out a spool of it in Home Depot one day as I was pretty curious about the same thing. Home Depot had it for just over $1/ft, so I was playing with on the spool. I couldn't even get it do a 90 degree bend with my hands. There was no way I was going to take the time to try and really run it through a firewall and under some carpet.
could you run it in combo with the reg 0ga we use for the bends u need?
edit: or would that defeat the purpose?
That would start to defeat the purpose. Another thing to be looked at is that with every connection you make (soldered or not) you pick up a small amount of resistance. So, with the number of cuts and joints you would need to make you may end up building up more resistance than it would be worth.
Chris - "The Apprentice" - Pandora's Box Customs
1994 Ford Explorer - "Midnight" - 4.0L SOHC
SoundStream PCX-1000D & Kicker S12L5
its all about surface area my friends
I have to agree but also if its soldered.
i have a question is solder bad for connections bc its not as conductive as copper right?
Solder is actually helpful, in the fact that it inhibits corrosion, and it does increase surface area. If you put a "generous" amount of solder on a connection, it will get between the strands of your wire, thus actually helping reduce resistance at the connector because you will have more of a pure, solid connection. And, most solder is highly conductive.
Edited by PandorasCustoms
ahhh i c thx for the info one last question is solder bad for connections bc isn't it less conductive than copper?
hmmmm very interesting
Try cross-sectional area.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
Just use audio wire haha the difference wouldn't be audible and now the convo is just getting too crazy. It's not worth the time lol
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
i had a question whats better whats better solid power wire or wire with more strains of wire my bro thinks solid is better he says it conducts better i said no so i want to know whats better :help: i have all 0/1 all threw my car
for power your brother is correct. Solid is better. IT's also a gigantic pain in the ass to run the wire. Since poewr in cars is DC you do not need to worry about skin effect, because there isn't any. That only comes in to play with AC, and even then only at high frequency. I'd rather run solid copper buss bars than the stranded stuff we have available to us.
Principal
JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it
Current follows the path of least resistance. A solid copper wire is going to have less resistance than wire with strands, but it comes at a cost (money and ease of installation).
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
ever try to solder single strand wire? give it a try and see if every solder joint doesn't break.
its not as conductive, yes. but there is more surface area. i dont know exactly how the math comes out but i would bet its an even trade off. if you crimp then solder that would be beneficial because the copper makes contact then the gaps are filled with solder.
X2 big time.
Edited by skittlesRgood
thanks for the info their is still a lot to learn thank you all for all the info :drinks:
  • Who's Online   1 Member, 0 Anonymous, 858 Guests (See full list)
