i have a manual tranmission on my car and i would like to do remote start on it, i seen videos with them, but i went to acouple local shops and they say its not possible and wont even touch it
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Clutch bypass! most shops wont do it but you will find one that will
I think it comes down to liability issues with it being on a manual trans cause if it starts and it is in gear and moves someone may get hurt or killed and i can understand why no one would do it.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
They definitely make em tho there's plenty of them look on sonicelectronix
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
Its possible. You just have to make sure when you park your car, to leave it out of gear, Use parking brake, and get a clutch bypass. Wouldn't there be included a gear sensor to tell if it was in gear, telling it not to start? That would be another thing.
Edited by Katt
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
All newer Vipers can be put in a manual trans car. Theres an "exit procedure" that must be followed, in order for the vehicle to be able to be remote started.
Front Stage: Kicker QS 65.2 Components, MB Quart Reference 5.25 in the a pillars,
Midbass: Kicker CVT8's in the rear doors,
Headunit: Pioneer DEHP880PRS - Running Active
Amps: US AMPS XT1600.4/XT800.4
No beat yet.
Twitter
Soon as remote start season ends, I'll be able to work on my car some more.
  • 2 months later...
i had a 95 pathfinder that i put a linear actuator on the clutch pedal. put it on the starter kill wire and left the factory kill switch as is. hit remoter start and the clutch drops then starts. just use the e brake.
Edited by Watts Shakin'
Allen Potter
USACI
streetbeat 4 World Record
9 State records
1 National points title
2 WF top 3 (SB4)
3 RD Super Heavyweight 18s
6 RD D9s
SB ???.?
burp 161.8
I did that for mine, but put it in automatic mode, that way I dont ahve to do that stupid procedure, the car wont start if its in gear anyways, cause I have the nuetral saftey wire up, and I always park with the parking brake, works perfect :D
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
If you have an actual neutral safety wire in the vehicle, just hook it up and there will be no issues. relay to connect/interrupt your clutch switch and youre golden
Edited by EVAlonSo
  • 2 months later...
run the ground out when running to the output wire of your clutch switch, basically the one that reads 12v when the clutch is up and ground when you press the pedal. i install car starters alot easier to do these things with a power probe My link
chevrolet all day er day.
'81 camaro z28 performance
'03 silverado ext cab show and go
