is the re audio box calculator accurate
ok so i used the re audio box calculator to design my box and it seems like its different from the torres calculator. here is what i got from both calculators
RE Calculator
Torres Calculator
damn, well looks like i have more tweaking with torres to do
Re calc doesn't account for bracing displacement, woofer displacement amongst other things. It's not terrible but not as accurate. Tuning will be different. Stick with Torres.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
its pretty accurate on the box area, but other than that yes the tuning is a few hz off, and it also seems like the port area is off.
I think there are like 10 threads about this on every forum I'm in. Stick to Torres
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
On torres' calc you have to put 3 common port walls for a slot port. Also, port area is off because you didn't account for wood thickness, so your port height on torres should be 1.5 inches.
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
1.5 inches tall? i thought it was the height of the box minus 1.25 inches because the wood is .75
  • Who's Online   1 Member, 0 Anonymous, 1031 Guests (See full list)
