ok so im starting to pick out the curcuit breakers i will use for my car and i know i need a 200A for my 1500-dbcp and a 150 for my 600-2 , i will be running a d3400 in the back only and should i have one for the wire that goes to the starter and main fuse box or no ? and i will be running a 200A alternator so does this mean i would need a 200A breaker for that ? and would i put that close to the alt or to the battery ? and also my main engine fuse in the fuse holder is an 80A fuse do i need to upgrade that because of the Alt or not ?
Edited by michigancapri92
always fuse for what the wire can handle, not the equipment attached to the wire. The fuse protects the wire, not the equipment. Why are you messing with your starter wire?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
relocated battery to the back of car and had to re-run wire to fuse panel and starter i have no battery in the engine bay and thanks !! dont know what size breaker to use for main wire and alt wire
i've used a circuit breaker before as a fuse, worst thing i've ever seen, always popped my kicker 4 channel into protect, and iirc it was a 140amp.
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
circuit breakers suck if you keep tripping them. after a few times, they will keep tripping on lower and lower loads.
circuit breakers can fail, i would recommend not using them, plenty of other people here will agree.
2007 trailblazer lthead unit- pioneer p4300dvd
crescendo ft-1 supertweeters
pioneer m650 pros
audiocontrol 2xs crossover
Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
i agree
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1402 Guests (See full list)
