amp fuses melted please help
Also look at how tightly the fuse is held by the fuse holder prongs
am unable to all the suround has melted into it
but yer im thinking the same thing..i think it shorted
Red light rev ya engines..light goes green u take off, petal to the floor.I take it slow but some how seem to catch up with u at he next red.So u think u can do it again.light goes green you stall..i put my foot down just to show u what fast really looks like :)
I wouldn't say shorted. I'm guessing poor connection and you were trying to pull some heavy current so the poor connection caused excessive heat and melted the holder
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
for sure it wasnt my ground..maybe the +
fuses too big?
I'm gonna say something at the fuse holder (fuse or wires) was'nt connected as tight or as even and flat as it needed to be. You're just going to have to get a new fuseholder, I like the "female" style fuse holers where the wire goes into the holder and you screw the wire down, instead of the bolt type fuse holders where you need to have ring
terminals. I'm gonna take a wild guess and say you had the bolt type fuse holder?
Something similar to this?
http://www.sonicelectronix.com/item_36278_Xscorpion-ANL1010P.html
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
yep but it didnt fk up there tho it stuffed up down by the amp fuses
ive also seen this happen from useing to small of wire
you got 1/0 4 guage or 8 guage to your 1500 watt amp? power and ground
fuses too big?
Kinda thinking the same... 4 40amper's for a class D??????...
You do know what the response amp is right?
Its made by Jaycar, it is zenon built, and almost identical to the Sundown SAZ-1500 which is also fused with 4 40 amps in a class d monoblock.
As someone else said, the prongs that phsically hold the fuse in the fuse sockets could of been holding the fuses too loose and with little to no contact they got hot and melted.
or you where running the amp at a lower impedance then the 1ohm stable it is rated for.
I Had a buddy with 2 saz-1500s strapped at 1.33 ohms and due to the added current draw for the lower impedance it would melt and pop fuses after a minute of full tilt play time.
  • Who's Online   0 Members, 1 Anonymous, 946 Guests (See full list)
