XS Power
All of the charging instructions here and on the website neglect mentioning alternator charge voltage. Are there negative repercussions for charging at 14.8V via alternator all the time?
IG @walledsonic
Reading > you
http://www.4xspower.com/Dseries-Instructions.pdf
http://4xspower.com/support/instructions/
There has been so many topics on that right here on this forum, either search here or Google but don't come in like that. Read the above links^
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Reading > you
I guess i'll be damaging my batteries then. I see a lot of folks on here in hot climates that i know are charging in the upper 14s. The word 'alternator' doesnt show up on the instructions, but XS charging equipment sure does. So i figured this thread would be a good place to clear that up. Btw Karkov, i found plenty of information on why the intellicharger is different than other chargers. Its pretty clear on the same link you sent. I guess we all have a topic we want clarified.
IG @walledsonic
  • 8 months later...
  • 6 years later...
I have 4 d3400 in the trunk. 3 1/0 tofc shca runs from 410a  js alternator . The batteries are ran parallel.  The first battery sees 12.6v resting then the next 3 are all at 11.52. I'm running 4 ppi 7000.1 2 strapped together and same with the other 2 pushing 4 skar vxf15d4 wired at 4 ohm. Those are all running off battery 4, battery 1 has my viair compressors , lighting ,and toggle panels. Batteries 2 and 3 have no load. Fused in-between all batteries, with grounds from frame on batteries 1 and 4...question is , why are all the batteries not the same voltage, I also see massive voltage drops if I turn the system up, like down to 10v. Can someone draw me out a wire diagram for what I'm running, please. Or are these batteries just done for? I hope not because if they are I might as well just toss 1600 in the John crapper and flushed it down the drain.
Go ahead and make a new topic so we can better assist :)
If it comes down to it, you're not that far from me. I'd be more than happy to give everything a once over too
https://www.stevemeadedesigns.com/board/forum/12-electrical-battery-alternators-wiring/?do=add
