Mha Posted December 2, 2011 Report Share Posted December 2, 2011 So I called a local audio shop and they wants to charge me 80-160 to install it(they said they had to see it to determin how much it would be). I looks like all I have to do is unbolt the old, remove the pos and neg and the harness and replace with the new one is this right? It also said to replace the the pos and neg to at least 2 gauge wire( im doing 0 gauge) but do I still conect the original oem wires and then run my 0 gauge wire byside? My truck has a doube battery tray one on each side( got a d3400 coimg in with in the next few day) to wire it up should I just run a second 0 gauge power and ground direct from the alt or should I hook it up to the first battery? Its a shorter run from alt to second battery then from 1st battery to second battery. Quote Link to comment Share on other sites More sharing options...
G-Rad Posted December 2, 2011 Report Share Posted December 2, 2011 (edited) Run the 0guage wire withthe OEM wire. There may be some thing conncted to the OEM wire, and f you dont have it on your alt, then that could be bad news for your components. As for installing Yes, it's not too hard, but be sure you disconnect your ground from the battery first before doing anything. For the 2nd battery, do a run of 1/0 from the first battery positive terminal to the 2nd batter positive terminal. Be sure to fuse the wire at both ends, within 18 inches of the batteries. Ground 2nd battery to the frame. Your alternator will charge your batteries, too. Edited December 2, 2011 by G-Rad Quote BASS MEKANIK RECORDS "Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold! 2007 Ford Focus (NOTE: My cousin's build I helped him with) Pioneer H/U (4) Absolute Dome Tweeters on A & C pillars Scosche HD683A's in front doors Fosgate R168x2's in rear doors SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz Audiopipe APCL-1800.1D Q-Mat Audio Technix 0 Gauge 119aH/850CCA Marine Deep Cycle batteries YouTube Channel: http://www.youtube.com/DWRhythm Link to comment Share on other sites More sharing options...
jmander11 Posted December 2, 2011 Report Share Posted December 2, 2011 (edited) Nvm ^ beat me to it while I was getting a drink on posting screen Edited December 2, 2011 by jmander11 Quote Link to comment Share on other sites More sharing options...
G-Rad Posted December 2, 2011 Report Share Posted December 2, 2011 Feel free to chime in if I missed anything though Quote BASS MEKANIK RECORDS "Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold! 2007 Ford Focus (NOTE: My cousin's build I helped him with) Pioneer H/U (4) Absolute Dome Tweeters on A & C pillars Scosche HD683A's in front doors Fosgate R168x2's in rear doors SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz Audiopipe APCL-1800.1D Q-Mat Audio Technix 0 Gauge 119aH/850CCA Marine Deep Cycle batteries YouTube Channel: http://www.youtube.com/DWRhythm Link to comment Share on other sites More sharing options...
n8ball2013 Posted December 2, 2011 Report Share Posted December 2, 2011 what truck is it? i know you have a tahoe or something right? what engine Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
newls1 Posted December 2, 2011 Report Share Posted December 2, 2011 OP, if you're swapping alts on a tahoe Either it be 01-12 or the older ones with the 5.7 in them, it is literally a 10min install. Remove belt, take out old alt, put new alt in (Make sure pulley is tight) replace belt.... Done. Now go and do it. Quote I love my staffie So anti FACEBOOK it isn't even funny Link to comment Share on other sites More sharing options...
Dangrebel Posted December 2, 2011 Report Share Posted December 2, 2011 Any gm truck or suv is super easy when it comes to putting the alt on. I can do mine in like 10 min off and on. Quote 1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps, Link to comment Share on other sites More sharing options...
Mha Posted December 2, 2011 Author Report Share Posted December 2, 2011 Thanks guys, its a gm you guys sound like pros I love this forum Quote Link to comment Share on other sites More sharing options...
newls1 Posted December 2, 2011 Report Share Posted December 2, 2011 Thanks guys, its a gm you guys sound like pros I love this forum NOthing really "PRO" about it. Changing an alt or alts on a tahoe/suburban is easier then changing the oil. I guess I've done it many times, but I can say even the first time was easy as hell Quote I love my staffie So anti FACEBOOK it isn't even funny Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted December 2, 2011 Report Share Posted December 2, 2011 Thanks guys, its a gm you guys sound like pros I love this forum NOthing really "PRO" about it. Changing an alt or alts on a tahoe/suburban is easier then changing the oil. I guess I've done it many times, but I can say even the first time was easy as hell it literally is, tensioner off, wires off, take out 2 bolts, take off alt, put new one on, 2 bolts back in, belt on, connect wires, tensioner on, done. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
