I talked to a guy at a local audio store, and he recommended a 12" JL WØv3 and a 360 watt JL amp bridged. He told me that this would give me the best SQ in his opinion, since I'm not really concerned with SPL. Is that true?
Decent, but your enclosure is much more important when reaching these goals.
Best? No, there are MANY SQ oriented brands out there. It will sound good but as HT said your box will truely be the deciding factor
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
Enclosure is the main aspect, lower tuning is optimal! Most SQ setups have a tuning in the mid 20's. The peaky higher bass of the 40+ range, is something to steer away from.
You can also run a small sealed enclosure and with the crossover of the amp tune it low or run and external crossover thats able to go down to 20 hz.
But......the enclosure is the most important, 10 & 12's are best for tight response due to the smaller cone area, but a 15" in the right enclosure is possible to sound good too!
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
Box dude, Seal that shit for the SQ son!
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
8's work well for SQ.... It is all in the enclosure really as others have stated... You can have a top of the line woofer but if you place it in a cheap box then it will sound like shit... You can place a cheap sub in a really nice box and get great sound...
If you are on a budget i would recommend looking at things like FI SSD or Sundown Sa series or possibly that new Skar stuff...
Team MaxRetribution
Si Vis Pacem Parabellum
Ok cool so I guess I need a kick ass box. Never built one before though. I'm guessing that would be way cheaper than buyin one? But if I were to buy one, what would u guys suggest...
build your own man..maybe have someone design you one :) WAY...WAY cheaper to build your own and when its done you can say "i built that"
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
Dont buy, I repeat dont buy! Build your own, to your car, to the subs specs, there are a couple people here on the forum, that can design the best possible enclosure for your needs.
Look up Ray and Ramdesigns, both guys are great people and will help with your enclosure needs, but I would look at a few differents subs. Check into Audioque, Sound Solutions Audio, AA/Fi, and Sundown. These companies make very solid equipment and can be SQ oriented. But as for JL W0, I would spend the money on a stronger more powerful setup.
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
  • Who's Online   0 Members, 0 Anonymous, 1758 Guests (See full list)
