i had a similar problem on my truck..try having someone pull on the hood (not hard but hard enough) while your pulling the release lever..thats how i get mine open when i need it..as to an actually permanent solution i have yet to find one <_<
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
X2
It sucks balls, but its the way it is on mine.
Or, roll down the window, pull the latch, and then run like hell to pull up on the hood before the latch shuts on ya. takes like 10 minutes but you'll get it eventually, lol
I hate long signatures....
...what the fuck is wrong wiht you you fucking fuckity fuck fuck head...
Mtnbikecrazy55 Feedback
Well I got it to work but since I'm still working on it I'm scare to close it ugh!!! If any one has a permanent solution please let me know
Just remove the hood, you don't need it anyway.
Hoods are for bitches.
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
2008 Subaru Forester XT
Posted (edited)
I have a 2000 camry. Their could be wiring problems you might want to check that(as in loose connection ect..) if it is the latch itself go get a new one at a junk yard for a whopping 10$ or so....
But just so you know you can get the hood open just get a good stern pull up and it will open just as you pulled the lever in the car..
I was doing some work on my car before(this is how I found out) and had the battery
disconneted, shut the hood and didnt realize I couldnt open it back up without electricity soo I thought I would have to fuck something up trying to get it back open. Good thing there's a few mechanics in my family to help me in my dumbass moments.
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Spray the hell out of the latch with pb blaster or good ol wd-40. And make sure the spring on the latch isn't getting stuck .
formerly known as Jaylor Swift
Adjust the rubber bump stops that the hood sits on. That should do it.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
your hood release is electric? i have never seen that on any car....only cable.
shit my moms mercedes is even cable lmao
damn toyotas bein different
HA. anyways i would do exactly what these guys are saying.... hose it down with pb blaster....i dont like wd 40 because it is actually like a degreaser in some of its chemical properties.... read the can "removes oil" or something like that.
also make sure your hood latch isnt bent....a bent latch WILL cause problems for releasing lol
good luck!
-jarrid
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
  • Who's Online   0 Members, 0 Anonymous, 695 Guests (See full list)
