I hooked up a battery charger to my trucks battery and I went outside 30 minutes later to look for my cell phone and my amp was ON and it was flickering in and out of protection mode. It was soooo hot I couldn't hold it. I quickly disconnected the remote wire thinking I was getting a signal from my head unit since I've been getting a voltage leak lately and it didn't stop. Once I stopped the charger, the amp went off. All that was connected to the amp were power and ground wires and it was still on. I turned the charger back on the the amp stayed off. WTF HAPPENED? I think it fried my amp. I'm so pissed right now.
E34 540iT/6
Did you see the magic white smoke off your amp?
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
not sure what happened but i believe most charger manuals say to charge a battery while its disconnected
^^^This
Maybe your charger is messed up. Can you check what voltage it is charging at?
Only reason that I can think of to remove your battery while charging is incase of a charger problem where its sending 120v to your batt. No way I would want to disconnect 6 batteries once a week to charge my batts.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
It was charging at 12.6v. I've charged it numerous times hooked up without the frying of past amps so I don't know what happened. No magic white smoke either.
E34 540iT/6
amp on when not supposed to, plus voltage "leak".
sounds like your amp had a short between postive and remote.
The leak is from my head units constant hot and key hot both being hooked to constant so my head unit is always drawing power.
E34 540iT/6
your power wire must of has strands touching the remote
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
