Best place to hook up a voltage meter?
Just fuse every wire and try the red blue and yellow in different configurations until you get it right. Black will be ground. Yellow is likely constant. But then again many overseas products use red for constant. Blue is likely metered value.
Okay so.. is the constant the wire I am hooking up to the power input on the amp? and when you say metered value you're saying what it is measuring voltage of?
E34 540iT/6
at the amp man
Ye dig, getting loud off little :D
(2) AQ HDC3 12
AQ 2200D - Replaced it, Works great
AQ4x90
JBL 662s 2 ways
(2)XS 5100r under the hood & A 170amp alt
post a link to where you baught it.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Yeah blue I mean to hook up along with the power source at your amplifier. Some need nothing more than that, but some require another actual power input which would be a constant, and id hook that up further before your amp. Ground I would tap into whatever is already grounded close to where it will be displayed. I know how these goofy little things are. Like I said though, if I don't know the colors for sure, I cut the wires, put female insulated quick disconnects on the ends where I cut, then place atc fuse in between. Helps protect the product just in case.
no, blue is almost ALWAYS switched input, ie REMOTE
I was thinking the same thing after reading that, haha.
Knowing computers that yellow will be your (12v constant)B+ and the red should be what you want to meter, black is ground, and blue should be the switch input as stated above.
Hell, think of it the same was as wiring a head unit.
on the stinger volt meter blue is the turn on. MY guess is yellow coould be a light switch
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
that is a weird meter . i agree to wire it like a head unit but to be honest if its a real cheap meter just get a stinger one and do the install once.
  • Who's Online   0 Members, 0 Anonymous, 1466 Guests (See full list)
