JasonJones Posted January 4, 2012 Report Posted January 4, 2012 So I've been told and somewhat seen with other peoples builds issues with replacing the OEM alternator in newer GM trucks, that the aftermarket will not communicate correctly or some bs. I plan on Doing a quad alt setup in an 07 Suburban but am skeptical about replacing the OEM due to what people say. If anyone has any input on this I appreciate the feedback!
FeArZ Posted January 4, 2012 Report Posted January 4, 2012 I started a thread because I have the same question about my 2009 Tahoe. http://www.stevemeadedesigns.com/board/topic/129909-pcm-controlled-ho-alt-experience/ 2009 Tahoe 2000bc Cresendo POWA Need 3500 2 Sundown Zv3 18 high rolled sexiness dual alt bracket with Singer alt(coming soon) Mtx Q(not sure if I'm going to use) Knu wire and RCA's Bass Head Bands Oh and a few pairs of Jordan's
Mad_Mike Posted January 4, 2012 Report Posted January 4, 2012 Just don't replace the OEM. Run three aftermarket for the system, and the one oem for the truck.
JasonJones Posted January 4, 2012 Author Report Posted January 4, 2012 Just don't replace the OEM. Run three aftermarket for the system, and the one oem for the truck. Yeah this is the easy fix but then I wouldn't be utilizing the stock position to its full potential.
UnderLoK Posted January 4, 2012 Report Posted January 4, 2012 The way I see it you have a few options... 1) Run all older style AD alts and deal with a charge warning on the dash - Not sure if there are any other negatives to this but we all run volt meters anyways. 2) Run one alt for your truck and the rest to the system - You loose out on one alt, but most run the truck + mid/high off that one 3) Run all of them off the PCM - This is how I run and voltage ranges from 12.8-15.9 (start), but generally in the high 13's 4) Get an MLA 3+4 is how I went, but the MLA isn't in yet. One day I'll get off my ass and get it in there. *Note: If you have a tow button or a tow package of any kind you can turn off economy mode (economy mode charges low or stops charging to save fuel). When you see your voltage drop into the mid to low 13's or less hit the tow button and wait a minute, it should jump back up or turning on the headlights in some models does it as well. Yes I know your lights are always on... Turning the switch matters If at first you do not succeed, you are doing it wrong! -ARSCheck out my walled TBSS build over here4 Fi Team 18s on 2 Cactus K9 DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500 Pioneer X8500 6 XS Power D7500, 1 3400S Second Skin 2 270a Mechman Alts
Lbox88 Posted January 4, 2012 Report Posted January 4, 2012 All of these threads are awesome because I am looking into get a newer Tahoe myself. Sick of driving a car with no power/space/4WD. UBL | Build Log
Mha Posted January 4, 2012 Report Posted January 4, 2012 What issue is there? What should I look for? I did mine with a mechman 270 and am kind if freaked out now. I told them what car it was for and the said it was plug and play. Should I be conserned?
SilveradoGoesBang Posted January 4, 2012 Report Posted January 4, 2012 I was also told replacing the battery upfront can cause the alt to burn up because of some censor? Not trying to jack ur thread I have a 2011 "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
FeArZ Posted January 4, 2012 Report Posted January 4, 2012 The way I see it you have a few options... 1) Run all older style AD alts and deal with a charge warning on the dash - Not sure if there are any other negatives to this but we all run volt meters anyways. 2) Run one alt for your truck and the rest to the system - You loose out on one alt, but most run the truck + mid/high off that one 3) Run all of them off the PCM - This is how I run and voltage ranges from 12.8-15.9 (start), but generally in the high 13's 4) Get an MLA 3+4 is how I went, but the MLA isn't in yet. One day I'll get off my ass and get it in there. *Note: If you have a tow button or a tow package of any kind you can turn off economy mode (economy mode charges low or stops charging to save fuel). When you see your voltage drop into the mid to low 13's or less hit the tow button and wait a minute, it should jump back up or turning on the headlights in some models does it as well. Yes I know your lights are always on... Turning the switch matters I'm thinking of just doing the same thing 3and4 as I just found out they make a MLA for the newer Tahoes. One thing about mine is that it doesn't have v4 mode I believe because it's a 4.8L.BTW does the HO alt running off the PCM throw any codes? 2009 Tahoe 2000bc Cresendo POWA Need 3500 2 Sundown Zv3 18 high rolled sexiness dual alt bracket with Singer alt(coming soon) Mtx Q(not sure if I'm going to use) Knu wire and RCA's Bass Head Bands Oh and a few pairs of Jordan's
FeArZ Posted January 4, 2012 Report Posted January 4, 2012 I was also told replacing the battery upfront can cause the alt to burn up because of some censor? Not trying to jack ur thread I have a 2011 Never heard of that one, but these newer trucks have a ground clamp that reads the ground off the main battery. So you have to upgrade that to 0gauge for the clamp to pick up the increased flow or some B.S. Thanks Chevy. 2009 Tahoe 2000bc Cresendo POWA Need 3500 2 Sundown Zv3 18 high rolled sexiness dual alt bracket with Singer alt(coming soon) Mtx Q(not sure if I'm going to use) Knu wire and RCA's Bass Head Bands Oh and a few pairs of Jordan's
