I currently have a psi 15 and have been hearing 2 12s may be louder. What ones should I go with? I have the jl 1000/1 amp and will get another if needed.
I would say either that one or this one.
lol you must re phrase your title to whats the stronger 12 not louder.... loudness key is in the build not the equipment
plus all you got is a 1000 watts you dont need very strong subs just 2 500 rms ones
well, ive got t2d4 12s and when i was running just 1 off of a t300.2 bridged i did a 141.xx and with the t1500.1bd cp i have now with 1 of the 12s i did 143.9 ( also did a box but it was my first and not the best ) The loudest 2 12S ive seen were 2 t1d412"s running off a t1000.1bd and did somwhere between 145-146 in a sedan. rockford is spendy though, im sure there are other great options with just as good if not better results.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
This topic is now closed to further replies.
