Nasty grinding sound while braking...
If it makes any difference, they seemed warped for a while before the grinding started. The slower the car is going, the more the grinding is audible. I washed them to see if it could be rocks stuck under the pad, but obviously it wasn't that. It's supposed to be in the fifties sometime this week, so that's when I'll look and replace the pads (at least :trippy: )
1999 Pontiac Grand Prix GT Click to see my build log!
(2) SKAR VVX-12
Hifonics Brutus BRZ2400.1D
Hey stupid. I got your report. You cant type a coherent sentence but yet think you can run this much power? You cant even hyperlink on the internet. You have no mention of power upgrades. You just want dat big boom dat make dem bitchez panteez drop. Next time you report someone make sure the one getting the report isnt the one you reported.
wheel bearing maybe.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I'd be willing to bet its the pads/rotors. The longer you Drive on them like that the less chance there is of just turning the rotor to fix it. Oh and make sure you grease the slide pins every time you change brake pads so the wear is even on the pads.
I had this on my celica. I changed the pads and rotors and still nothing i took it in and it was the struts. Its like when you brake pretty fast its less audible but i slow braking it drives you crazy ha :D
Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center]
Build Log
http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/
2005 subi STi 380whp 355whp
17" gold bbs
5% tint all around w/sunglare strip
JVC dvd double din
Knuconceptz 4ga wiring
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
Brake pads and rotors. I wouldnt even bother trying to re-surface the rotors. Just get some new ones. Majority of the time, the inner pads will wear faster then the outer. so pull your wheels and see if the inner pad has gone metal to metal. Or run your finger along the front and back of the rotors to see if it feels rough. If it feels rough, then you did go metal to metal. The rotor is supposed to feel "smoother" to the touch. DO NOT touch it after driving though, cause it will not feel good.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
99% rotors and pads. You may also have a bad wheel bearing, or possibly strut tower bushing... believe it or not bad bushings can feel like warped rotors / bad wheel bearing.. jack up the car and see if the strut tower feels loose or makes any noise when moved at the strut base...
Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
Just from experience... I wouldn't rule out new calipers if you've gone metal to metal for any length of time or the calipers already have high miles on them. I went metal to metal last year and bought new rotors and pads. 6 months later a caliper froze up and ate my new rotors/pads up on one side. So that was two brake jobs in under a year.
Autozone usually sells what is known as a "loaded caliper" which comes with brake pads and calipers, it was only 25-30 more than just the pads.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
im going to throw this out here from one Grand Prix owner to another check your hub assemblies as well. They are the most problematic part on these cars.
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
TaylorFade, on 02 Jul 2013 - 9:38 PM, said:
Go back to that place, ask to speak to that dude again, look him dead in the eye and then.... pop him in the snot box.
Tell him T-Fade sent you.
  • Who's Online   0 Members, 0 Anonymous, 1677 Guests (See full list)
