yea then that power acoustic 6000watt says 250 fusing so wayy underatted
the 6000 watts is the peak power.if you look at the specs on the amp the rms says 3500 watts(which is probably at like 16 volts or something).never pay attention to peak power ratings on amps or subs as they are pretty much useless and pretty much used as a selling point.rms rating is what you should look at
the fusing total? as in the fuses on the amp?
Yes.
Let's look at the Sundown SAZ-3000D. It is rated at 3000 watts rms @ 1 ohm, and it requires 300 amps of fusing. It's fusing agrees with the rated output claims.
Now let's look at the Power Acoustik BAMF5500. It claims to do 3200 watts rms @ 1 ohm, but it only has 200 amps of fusing. I would say that there is no way it would ever put out more than 2200 watts at any given time simply due to the manufacturer's fusing.
My general rule is that if the manufacturer claims 'max' or 'peak' ratings on it's product, then it is most likely garbage.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Yes.
i do agree with your peak ratings rule and i know you said "most likely garbage",but i just wanted to point out to the OP that a lot of companies that use peak ratings arent the greatest but some good companies do use peak ratings,DC for example uses peak power ratings on their subs and they are a reliable and reputable company
ever heard of these amps
http://www.crutchfield.com/S-X9GgiMTwk6G/p_109BP1200/JBL-Power-Series-BP-1200-1.html
a buddy of mine is willing to sell me 4 of them for 175bux
Walled 2002 buick century A.K.A "Betty sue"
polk 5 1/2 front doors
4 3in pillar speakers
DD 3518's
AQ 3500 v2
90ft of 0/1 ga
tuned to 40hz
:build: http://www.stevemeadedesigns.com/board/topic/162721-buick-built-in-trunk-fi-sp4-hifonics-2400/
That JBL amp is a very good amplifier used by a lot of people years ago and will do rated and some. 175 total for 4 is a steal but not each for 175
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
The AQ will do 2200 rated rms no problem, but the Hifonics won't do 3000 rated rms but around 2200 rms like stevog says.
Companies like to overrate their amps so they can trick un-imformed people into buying it.
We are trying to inform you so you don't get disappointed.
Yeah, with no voltage drop. Still not a bad choice.
db-r has the sax-1200d refurb and b-stock for around that price.
If they're the Audiobahn AW1571J I wouldn't count on them taking 500wrms a piece.
Also if you're looking at getting a second battery for the back do NOT get a battery that isn't sealed, ie if it has openings to add water don't put it in your car, it'll vent toxic gas as it works.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
for the hell of it i bought http://www.ebay.com/itm/180774564315 we put it in a friends caddy trunk hooked to a single extra battery,dd 3510 in a custom box. we clamped it doing over 1300wrms at 2.3 ohm. it has 150a fusing so i was thinking it would be 1500-2000w max. so for $175 i got a cheap amp that does decent power.
on a side note- there is no way i would put one in my truck.lol
03 Santa Fe E A 200 amp alt,JVC AVX840,kenwood 6.5 fr speakers,eclipse 6.5 rears,mids/high amp XTA-2160, sub amp XTA-5000d,0 guage throughout,batts-front/1 batcap 2000,rear/ batcap4000,2 C&D Dynasty agms, subs 2 DC XL M1 15"s in a music box tuned to 28hz....for now.
if anything get a soundstream amp, i got the audioque 1200d and that amp is soooo amazing, deff puts out more then 1200rms..but just look into the hifoncis brutus series, they will do rated..but just fyi my friend had the brz1700 and my amp blew it away..i was surpised to be honest lol
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
