1 ohm and 4 ohm same amount of power?
Thanks guys much appreciated and im running a dc audio level 4 18" with level 5 soft parts so im looking for an amp that could put around 1500 watts to the sub daily.
2003 Chevy Tahoe
Pioneer AVH-P3200BT
18" DC Audio Level 4 w/ Lvl 5 soft partsAQ2200
JL Audio E6450JL Audio Mids and Highs0 gauge welding wire0/1 gauge big 3 upgrade
6 inch Suspension Lift
3 inch Body Lift
17" American Racing Wheels
37" Toyo Open Country M/T's
K&N Cold Air Intake
Throttle Body Spacers
SuperChip
4.88 Running Gears
MagnaFlo Exhaust
its less distortion and higher efficiency at 4 ohms if im not mistaking
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Depends really on the application... 4ohms will be more efficient than 1ohm and thus sound better and have less energy given off as heat.
more resistance = more heat. 4ohm is more resistant than 1ohm.
False. At least for equal power.
However the same current through 4 ohms will be more heat than 1 ohm, but it will also be more power, so its not really the same comparison.
did you just disagree with me then say the same thing i said? :ehh:
The 4 ohm setup would be much more efficient. And possibly even let the subs handle more power. At 4 ohms an amp will Run at a higher output voltage and a lower amperage which in the end means less heat being generated and more of the power being used to move the speaker. It's the main reason pro audio drivers are almost never seen below 4 ohms.
2000 Subaru outback 2.5l
Head Unit: Pioneer deh 4300ub
front stage: tbd
subwoofer: Stock Fi Q 18"
amp: Audio que 1200d
True, Got that one wrong once i thought more. I guess I was just thinking about how amps have gotten hotter on 1ohm vs 2 or 4ohms and I guess that's mostly to do with the amount of current it draws, if an amp was producing the same amount of power at 4ohms it would be significantly hotter than at 1ohm and draw a bunch more current.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
False? It an amp could do the same power a 4 ohm it would b much more efficient.. And it would have LESS heat than one that did the same power at 1ohm..
Laying frame soon.. System has to wait
I'm tired of people thinking 1 ohm to 4 ohm means more heat. Efficiency and wave quality in this context doesn't mean much to me :shrugs:
The low ohm would have lower voltage, higher amperage right and equal it out right?
If you are comparing 2 totally different unspecified amps then there's no way anyone can answer this question.
No, I disagreed with you then gave the only situation what you said would be true, which isn't this situation.
im actually talking about the speaker, not the amp.
  • Who's Online   0 Members, 0 Anonymous, 933 Guests (See full list)
