XS Power
Yes, the XP3000 does have smaller pads than the D3100. That is a limiting factor in the instantaneous power output. Like has been said many times the XP3000 has less instantaneous power than the D3100. It has even been brought up that you couldn't use the same buss bars to hook up XP3000 and D3100 together, because the terminals are different.
The pads on the XP3000 is actually like the old D3100 pads, and they still have close to twice the surface area that the other battery in that video has.
Edited by Nathan@XSPOWER
hey man, can you do a load test like in
his video? im pretty sure it'll only be 10minutes of you time.
and it will make us all happy, you can just compare it to the d3100 if you dont have other batts
It is rated for 3000 watts, So do a load of about 250-300 amps for X amount of time. Would like to see 30-60 seconds. We know its not the d3100 so no need to compare them at 500 amps. I ordered two of them and am very curious to see a test on this battery.
well i just compared the xp3000 to my d975, and the d975's terminal pad was larger smh.
http://www.youtube.com/watch?v=NaGPCIJZkwU&feature=youtu.be
There is less than a .5V difference on a 30 second 500 amp load between the XP3000 and D3100.
Why u guys keep complain as Nathan explain in earlier post what the difference was, if no one likes it just don't buy this type by the D series that simply majority of ppl complaint won't even notice the difference unless used in burp applications other then that its fine for street beating
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
Batteries showed up today. The packaging was awesome. These things are heavy.
-98' Ford Expedition (Rest in Peace)
-AVH-P3300BT
-Crescendo BC5500
-4 18" DC m2 Level 3.
how do you get a promo code to get the discount?
02 Dodge Durango
1 Fi SP4 18" .v2
Sundown SCV3k @.5 Ohms
XS D3100 up front
Northstar SMS AGM 400 in the back
All XS Power 0ga OFC
240a Apex h/o alternator
Pioneer AVH-X2500BT HU
Dual 0ga runs from the alt to battery
Dual 0ga runs from battery to amp
is audiosavings sold out of everything but the xp2500? bc thats all i am seeing now. Was hoping to buy a XP950.
Thanks!
--Andrew
06 Jeep Grand Cherokee
2 DC Level4 12"
Soundstream TA1.3000d
4 RF Punch 6.5" Components
2 RF Punch 3.5" 2-ways
RF Prime 400.4D
XS Power XP950 +&-run of XScorpion 1/0 OFC My Civic Build
