I ran two runs of 4 gauge stinger hpm for a while, it worked great. However I did not drop as low(voltage wise) when I got a run of 1/0 instead of the 4. I have dual 4 gauge inputs on my amp.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
well i was thinking dual input 4ga wire so 2 runs of 4ga to dual inputs on a aq1200.1D cause with KNU you gotta shave 1/0 so flipping much to fit it in the aq1200.1d
i like it shaved
2 12ks and i dont know what to do
build in the works!
If you go by how people rate wire size when you double runs below 1/0 .
U subtract 3 from the wire size for each identical run.
Two runs of 4 gauge = 4 - 3 = 1 gauge
That is technically smaller than 0/1 car audio wire.
Car audio 0/1 is like welding wire 2/0 and is more than 1/0.
Or that's what I've been reading and done some handson research myself.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
AWG is AWG no matter what it's used for. Also, don't forget to check what material it is made of. Two reasons to only deal with reputable companies.
1/0 awg = 53.5 mm^2 cross section.
4awg= 21.1 mm^2 cross section.
So you're right the 1/0 would have more current handling capacity.
i didnt mean it like that, i meant the way they rate the wire size and all.
car audio rated 0/1 is comparable to 2/0 welding size.
HMU!!!
95 Bonneville SSE
Same material, same cross sectional area, same current handling , same shit. My 1/0 welding cable is the same as my 1/0 car audio cable.
Edited by 87regal
