+ Run from alt or battery?
Fuses don't cause resistance.
Rephrase: don't cause enough resistance for me to give a shit about lol. .005 ohms of resistance might be a big deal to some people ;)
the pic i posted is how to wire a extra battery
That will work, but I prefer to run an equal number of negative runs from the front battery to the rear as I have positive runs. No separate ground.
-Zach-
2010 Toyota Tundra
Full Hybrid Audio SQ
7" BDS on 37's
2000 Ford Expedition
160+ dB Green Turd -SOLD- :(
we did mine where there power wire went from my starting battery to the secondary then the ground wire from the cars chassis to the negative of the battery
people who have bought from me Team Bassick (ALPINE) Purplehaze nidus
head unit sony dsx-s310btx
subs 2 12 incriminator audio king of bass
subs amp incriminator audio 20.1
mids/highs
mids/highs amp incriminator audio 6.4
equalizer clarion
crossover interfire
alternator 1 mechman 240amp
battery's xs power 1 d2100 2 d3100
sky high car audio 1/0 awg ofc wires
memphis car audio 1/0 ofc
xs power xs flex 4 awg
sky high car audio 8 gauge ofc
sky high car audio 12 gauge ofc
t spec rca
check out my building log http://www.stevemead...frey-build-log/
http://www.stevemead...d-other-things/
check out audio gear i have for sale
http://www.stevemead...51#entry1595151
iu was talking about this man will there be more resistance?
put a fuse in the line from the battery to the amp regardless of the amp having fuses or not.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Imo.. best way to do it is 2 pos 2 neg per alternator... I. Also put a 3rd pos wire an neg wire from battery to alternator....plus multiple chasis grounds front an back.....just in case...serious spl competitors do 1 run of 0g per 100amps of current draw...do neg runs front to back alternator to back batterys.cause the back half of alternator is the actual ground that completes the 12v circuit..and you will get minimum resistence that way.which means more voltage amperage to your batterys an amps
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   1 Member, 0 Anonymous, 1442 Guests (See full list)
