just got kicked out of the audio game (update)
Isn't the smd's the only sub that has the motor bolted on? I swore I read that somewhere
Or is it that the smd is the only sub with the motors bolted together so it doesn't shift...
lol no...
my 12" re audio xxx was bolted,
along with my 12" alpine type X
and the 12" JL W7V3's.
all bolted
adire isnt shitty, and i traded for these, these subs were origonally 699 a piece,
oh btw all motors are held together by epoxy,
yes they bolt to the basket but the slugs are epoxied to the top and bottom plate
adire is a bad brand of woofers.
JL W7's are also $699 a piece for the 12's.
expensive subs do not make a good sub.
jl doesnt bolt there magnets on. they are like rivited on
gonna try some 5 minute epoxy or something and if that doesnt fix it i wont have anything i can do until atleast august, hopefully i can get a job by then
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Isn't the smd's the only sub that has the motor bolted on? I swore I read that somewhere Or is it that the smd is the only sub with the motors bolted together so it doesn't shift...
lol no... my 12" re audio xxx was bolted, along with my 12" alpine type X and the 12" JL W7V3's. all bolted
adire isnt shitty, and i traded for these, these subs were origonally 699 a piece, oh btw all motors are held together by epoxy, yes they bolt to the basket but the slugs are epoxied to the top and bottom plate
adire is a bad brand of woofers. JL W7's are also $699 a piece for the 12's. expensive subs do not make a good sub.
i donno man.. these look like bolts.
apologies for the low res on the heads
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
And another person feels the pain of the motor assembly falling apart.
Been there, done that, stopped buying subs without a fully-bolted motor.
Seriously depressing that in this day and age most manufacturers are relying on glue to hold magnet assemblies together..
EDIT
Robby - those bolts are only to the top plate likely.
Hammerdown... 1%
well i sat the plates back together and toyed with it abit, i got it to where the coil wont rub and the sub will play when power is put to it,
i'm gonna go get some 5 minute epoxy and clean the mounting surfaces then put the sub back together
tear it apart drill and tap holes to bolt it together instead of glue/epoxy and get with sundown or dc and get them to build you a recone.
Your kidding right?
Really dude... drill a magnet? Where do you think the filings are going to go?
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Suck it up, fix it or find another solution.
Plenty of people with no money break stuff all the time, and if they love audio enough, they find away to keep bumping.
Some good suggestions were listed above. There is always away as long as you are willing to keep your mind and heart open to audio.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Idea:
cut the dustcap out with an exacto knife, shim coil as if you were doing a recone so it aligns the motor/coil, glue it up however you deem fit, and glue another slightly larger dustcap on :)
^^ this but say on the side of the motor take a silver sharpie and draw a line down the top plate onto the motor then pull the basket part off lay the apoxy and then put the basket back on to the motor making sure to line up the sharpie mark. That's what I would do.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
  • Who's Online   0 Members, 0 Anonymous, 1099 Guests (See full list)
