depends, are you gonna do a cheap job or if you are gonna do it right.
carpet would probobly be cheaper because its only glue and carpet.
as for paint you may need filler, youll need to sand the box, and youll need primer and paint
or if you do birch plywood you can stain it and use different finishes like gloss or satin
Edited by bass_stalker
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
There's many things you can wrap with instead of carpet. I like leather and suede. I think paint looks shitty unless you have the right paint, spray gun, and experience.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
i spray painted mine and it soaked that stuff up like nothin, so tomorrow ima just paint it with a brush or something. i heard that carpeting can lose dbs and painting can help gain Dbs to idk man go with whatever. i like to paint cuz you can do different colors and be creative :detail:
i do paint. 2 coats of primer then 2-3 coats of paint then 2 coats of clear. usualy come out nice and smooth. make sure you fill in your screw holes. i usually countersink them then use wood filler.
What about rubberized undercoating like u get at AutoZone? Would that be ok for him to use? Its pretty cheap!
i just spray painted mine. it came out good enough, not show room quality but not bad for just a $1.
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
  • Who's Online   0 Members, 0 Anonymous, 1978 Guests (See full list)
