soundstream15 Posted April 3, 2012 Report Share Posted April 3, 2012 my box i currently have is great but the port inside the box is alittle loose so i was gonna buy silicone and redo the inside of the box, but idk if i should use silicone or caulk? if i go over the edges n that will it make a difference? also is there any type of screws that hold the sub tighter to the box then using dry-wall screws. thanks Quote Link to comment Share on other sites More sharing options...
Sanitarium Posted April 3, 2012 Report Share Posted April 3, 2012 if the box was built right, a light sealant like that is not needed. My vote is to just rebuild the box. Quote Link to comment Share on other sites More sharing options...
uhoh_45 Posted April 3, 2012 Report Share Posted April 3, 2012 use glue... Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
SnowDrifter Posted April 3, 2012 Report Share Posted April 3, 2012 Fiberglass 45s They seal it and make it stronger Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
ALPINE408 Posted April 3, 2012 Report Share Posted April 3, 2012 Ya its called wood glue And if you want better screws then dry wall try deck screws Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
Smoove Posted April 3, 2012 Report Share Posted April 3, 2012 I am a fan of liquid nail for gluing and sealing a box. There are others why will say fiberglass the with mat for sealing. both work well. And no going over the edges will not hurt anything. Quote 2 Team Fi 15's v1 2 DD M5's 970amps of Alt 6th order blowthroughThe truck Blowthrough build : http://www.stevemeadedesigns.com/board/topic/155555-smooves-1996-chevy-ext-cab-c1500-slow-build/The 350z build : http://www.stevemeadedesigns.com/board/topic/170694-smooves-2003-nissan-350z/ My FB page https://www.facebook.com/pages/Smooves-Car-Audio-and-performance/719746144805343 Team Fi Audio http://www.ficaraudio.com/ Link to comment Share on other sites More sharing options...
ALPINE408 Posted April 3, 2012 Report Share Posted April 3, 2012 (edited) Liquid. Nails is garbage for a box you can take the box apart and peal the liquid nails off I have done 160 dBS with just wood glue and screws sealed just fine w ithout a drop of fiberglass Edited April 3, 2012 by Team Bassick (ALPINE) Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
soundstream15 Posted April 3, 2012 Author Report Share Posted April 3, 2012 so deck screws are better to use then drywall screws? i just feel like dry-wall screws come loose and dont get that tight Quote Link to comment Share on other sites More sharing options...
Keith77 Posted April 3, 2012 Report Share Posted April 3, 2012 (edited) Dry-wall screws are meant for dry-wall. Use wood screws. Edited April 3, 2012 by Keith77 Quote Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born. My penis is bigger than your penis I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle. Link to comment Share on other sites More sharing options...
SojiaRaggs9000 Posted April 3, 2012 Report Share Posted April 3, 2012 I've always like using Liquid Nails "for wood" it has a resin mixture in it. Works well and holds fine imo. But thI've used some SOUDAL INC T-REX CAULK before and that stuff was great. I got it from Ace Hardware.... I tried to used some pieces off of a box that I used this on and I had to take a sledge hammer to it to break it apart. The glue held but the wood broke haha. Quote * Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )* Rockford Fosgate Balanced Line Driver * One FULLY LOADED ~ 10" DC m2 XL* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling* MechMan 240a High Output Alternator * KnuKonceptz Krystal Kable RCA Cables* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable* Five Exide Orbital ORB34M Marine 12 Volt Batteries* PowerMaster XS D3100 12 Volt Battery My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold Link to comment Share on other sites More sharing options...
