Real men wire at .35 daily..lol I have for 2 plus years no issues.....and with 5 different amps.. I don't suggest this to everyone....
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
So this is just a little explanation of why when we run at .5ohm it takes a big alternator or 2 and a few batts.
If anyone has ever had a 2ohm stable amp and tried to run at 1ohm without sufficient electrical they have probably experienced amp shutdown at volume, but most people don't understand what's going on electrically. The problem is called voltage dip, and it occurs when impedance is very low. As the impedance decreeces the curent increeces, and consistently voltage drops, the problem is literally that the impeeadece is so low the electrons are moving around the circuit so quickly that it's a near short circuit. And as most of us know the way to avoid this is to get a bigger alternator. The biger alternator can provide the curent the amp is asking for to combat voltage dip. The moral of the story is either beef up the electrical or raise your impeadance!
I almost want to stop going for an electrical engineering degree now.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
if u just did online reaserch and then posted what u found, did you REALLY think we didnt know what we were doing? have u been around audio comps? most people are running below rated ohm load. y would audiophiles not know this
Edited by t-money
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
I'm sure everyone knows how to run at lower than rated impedance, I was try to explain why in semi technical terms, that people need more electrical. The vast majority of people on this forum can ignore my "moral" because like several persons have pointed out, "we already knew that" (that being of course you need a bigger alt and batts).
i didnt have problems until i hit .25 ohms lol
couldnt get a burp off but let me tell you sundowns protections circuits are great
im retarded and they havent blown yet. thats all i will say lol
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Although there were some mistakes and inconsistencies, I applaud your effort. Instead of a "my friend says X brand is the best" or "a shop said X brand is trash and Kicker is the best" you made one to try and help further knowledge.
I would say even more research and actual experimentation might help solidify the rules and properties for you and be fun in the process.
I never run below manufacturers recommended impedance any more to many problems if I need more power I get a bigger amp
Plus for that few hundred extra Watts your making way more thd current draw and heat all bad things
So put it this way running lower ohms
Pro
More power
Cons
More heat
More thd
More current draw
And there is allways the possibality to blow your shit up
Cons highly out weights the 1 pro
I can see competitors doing it to battle rise and staying within guidelines, but on a daily setup just doesn't make sense to me. I've wired low before but that was to test equipment, not to run at. People are still going to run at lower impedances, and that's fine. The real problem is when Joe Schmoe reads/sees it and blows his amp because he wanted more power.
Really interesting thread and I think its all good stuff to know. My experience with running lower than spec resistance killed my first amp and I didn't really understand why, so I've been running no lower than spec ever since. :good: Thanks guys.
