Impedance question...
Ok, so I am getting ready to pull the trigger on a Fi SP4. But I have something on my mind...
The specs on Fi's site say this:
DUAL 1 | DUAL 2
0.65 Ohms/coil | 1.27 Ohms/coil
I want to have it wired to .5 ohms (crescendo 3500) but I have a concern:
If I get the dual 1 I am worried about the amp seeing 1/3 ohm instead of a half ohm because of the .65 ohms/coil as per the specs, or would I be OK because it's a dual 1 ohm coil?
i would think after impedence rise you should be fine but thats just my 2 cents
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
go dual 2 then and amp will see .5-.7 wired in parallel. that'd be a safer bet anyways man
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Re is the DC resistance of the sub not the impedance, any sub measured with a multimeter will show a lower value than the impedance rating.
OP - why did you bump the thread? Joe X provided you with the correct answer.
The sub is dual 1 ohm.
Current system:
Previous systems:
I get the nominal resistance will always be lower than rated.
I am just nervous about having 1/3 ohm nominal.
