Anyone know if this type of port division would cause any issues? 3 inches wide, 26 inches long total. 2 12" DC LVL 4's SUBS FACING UP!
Edited by LongHairDontCare
GeekSquad Lead Autotech
MECP Advanced Certified Installer
2016 Ford Mustang S550
Stock system for now..
well, each split of the port should have half the cross sectional area of the combined port. So either move the back end of the L half the distance to the back wall, or double the width of the distance between the sides of the combined section.
2007 Pacifica
Not sure if that is enough port area, not a port math person myself. It does look like your port stays the same width (3") after it bends into your enclosure. If that is the case, you need to fix that.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Not enough info.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Dang, thanks that makes sense. totally overlooked that! But there wouldn't be a problem splitting the port? as opposed to having one single port channel? Thats my real question. & guys the box is 3.5 cuft., with 13 inches of port per cube, tuned to 33hz.
Standard slot vent looks good to me.
As stated, just make sure you work the port width right.
If I have minimal turbulence with my setup:
Then you should be good with a normal rectangle slot vent. Make sure it isn't to tall and skinny either that could end up hurting you.
-Drew
uhoh_45 said:
you just wanted to show off that sexy ass port.
2007 Pacifica
as long as both subs get identical signal you should be fine, all other factors considered.
2007 Pacifica
Thanks for the answers guys, love this forums willingness to help! I'll try to get a build log going with this! :D & sorry for being such a noob lol im working on it. :noob:
:ph34r:
-Drew
