sbelew Posted April 21, 2012 Report Share Posted April 21, 2012 I tried searching the forums several times but keep getting this error message; One or all of your search keywords were below 3 characters or you searched for words which are not allowed, such as 'html', 'img', etc, please increase the length of these search keywords or choose different keywords. So, I used the DD-1 today as per instructions, and on the head unit it detected no distortion all the way to max volume, which is 35. It is a Kenwood KDC-X695 I tested it both ways, using the RCA's connected directly to the DD-1 and also through the amp. I then proceeded to adjust the amp gains, and turned them up till I got distortion then backed them off. Is it possible that my Head Unit does not distort? Quote Link to comment Share on other sites More sharing options...
HatersGonnaHate Posted April 21, 2012 Report Share Posted April 21, 2012 I've heard that a lot of the Kenwood Excelon head units are clip free. So you should be good up til max volume. Quote My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol srp365 - If posting were picking up bitches, I'd be going home single tonight looks like tony montana sneezed in your car. Link to comment Share on other sites More sharing options...
OrionStang Posted April 21, 2012 Report Share Posted April 21, 2012 Excelons don't clip. Unless you use 'Loudness' and 'Bass boost'. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
zack_e89 Posted April 21, 2012 Report Share Posted April 21, 2012 I have the X396 and it sounds better than any pioneer or other head unit that I've had(all under $200). Quote 97 Suburban 8 custom PSI Platform 3 18's Link to comment Share on other sites More sharing options...
stroupe79 Posted April 21, 2012 Report Share Posted April 21, 2012 I knew there was a reason I loved the kenwoods i ran a couple years ago! Quote http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
sbelew Posted April 21, 2012 Author Report Share Posted April 21, 2012 (edited) No I don't use the bass boost or the loudness. I will bump up the sub level when I'm listening at low volumes on occaision, if the song doesn't have a lot of bass output. I also use the crossover adjustments on the HU as well, with the crossover adjustments on the amp turned all the way up. Just seems more accurate that way to me. Amp adjustments aren;t marked very well. Just an FYI, Prior to using the DD-1, I used the "turn the HU volume up to 3/4 and adjust amp gains by ear" method. It proved to be way off. With the volume set at 27, the amp gains I had set about half way. Now with the DD-1, HU at 35 and amp gains set between 1/4 and 1/3. Amp ran hot before as well, so Im hoping with the gains set lower, it will run cooler. Its a nice little device. It was my first time using it and only my second system install. Took me about 30 minutes, but I double checked everything and was reading the manual as I was going through it. Thanks for your help guys, much appreciated. Edited April 21, 2012 by sbelew Quote Link to comment Share on other sites More sharing options...
One Way Posted April 21, 2012 Report Share Posted April 21, 2012 Yeah i love my kenwood... But if u wana use the 4v to ur advantage u have to put the level on HU up, not all the way tho because u will get distortion. Find out the highest u can go with ur dd1 Quote T-line build- http://www.stevemead...e-t-line-build/ Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted April 21, 2012 Report Share Posted April 21, 2012 my 595 doesnt clip unless i boost on the HU. Quote Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
sbelew Posted April 21, 2012 Author Report Share Posted April 21, 2012 Yeah i love my kenwood... But if u wana use the 4v to ur advantage u have to put the level on HU up, not all the way tho because u will get distortion. Find out the highest u can go with ur dd1 What level are you talking about? Quote Link to comment Share on other sites More sharing options...
Trey_Dog650 Posted April 21, 2012 Report Share Posted April 21, 2012 Sub level out has to be turned up all the way! It's not bass boost or loudness. It's sub level. There's a difference Quote 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head. Link to comment Share on other sites More sharing options...
