So I got my battery "rack" done, I plan on screwing my aluminum buss bar on some 2x4's. is it ok to have it directly on them? I heard some people say thats its fine and wood is an isolator and others said sometimes wood can conduct electricity. So whats the verdict? Thanks
If it were mine I would use some rubber washers between the 2.
Yeah, for sure, but The screw will still be into the wood touching the bar. ugg i knew i'd run into this problem lol
Use a plastic anchor.
Wood is an insulator
oops, my bad. So, Ill be ok then?
Yup. For the inside of the car right? If so, then you should be fine. Using plastic washers and such won't hurt, but it's overkill IMHO.
P.S. I wasn't correcting your spelling, just confirming that we were both talking about the same thing :)
