Mikey Bates Posted May 29, 2012 Report Share Posted May 29, 2012 So i want everything in my system to be turned off and on with their own switch, and then a master switch. i have a lot of lights and im going to have fans and such. right now. I run a wire from battery to a switch, and then to my underdash lights. that works good for a small setup. but im getting this distributer . . . the main wire is going to be a fused 4 gauge strait from the front battery. and then each accessory from that (this only has 6, im getting one with 15) im going to put in a switch for each one. my questions is how to put a switch on the 4 gauge wire? i am also going to have some extra batteries in the rear with a few runs of 0 gauge running up front but this 4 gauge will be to the front battery suggestions? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 29, 2012 Report Share Posted May 29, 2012 you could do a circuit breaker for the 4 gauge. thats the only thing i can see being used realistically Quote Link to comment Share on other sites More sharing options...
Mikey Bates Posted May 29, 2012 Author Report Share Posted May 29, 2012 you could do a circuit breaker for the 4 gauge. thats the only thing i can see being used realistically I found this. .. if i put it like under my dash where its reachable is that ok? as in does it matter where it is realative to the battery or whatever? Quote Link to comment Share on other sites More sharing options...
baaudio Posted May 29, 2012 Report Share Posted May 29, 2012 you could use a battery isolator solenoid and use the turn on input to switch it on or off Quote Team NWSPL baaudio Build Log 2001 GMC Sierra walkthrough 4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k Link to comment Share on other sites More sharing options...
OrionStang Posted May 29, 2012 Report Share Posted May 29, 2012 Hit up CE Electric, looks like thats where you got the distro block. Snafu should know what you should use. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
Torres Posted May 29, 2012 Report Share Posted May 29, 2012 (edited) i was going to suggest one of those circuit breakers too. just have it go in to one side, out the other. and make sure the fuse rating is bigger than what your wire is fused at. you want that acting as a switch, not a fuse. Edited May 29, 2012 by Torres Quote Link to comment Share on other sites More sharing options...
hdorre Posted May 29, 2012 Report Share Posted May 29, 2012 Hit up CE Electric, looks like thats where you got the distro block. Snafu should know what you should use. I was going to suggest this. You can either: Call: (602) 999-0942 Email: [email protected] Make a thread in this section or PM Snafu Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread Link to comment Share on other sites More sharing options...
Wicks Posted May 29, 2012 Report Share Posted May 29, 2012 Try to switch off all the small switches (loads) before you cut the master. Mechanically switching a high current line will lead to arcing on the contacts which will increase your inline resistance and cause voltage drops. It'll be damn expensive but a solid state DC relay would be a great option. Quote This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026 Link to comment Share on other sites More sharing options...
snafu Posted May 30, 2012 Report Share Posted May 30, 2012 Mikey, I do this all the time. Hit me up at any of the above and give me some specifics on exactly what you want to turn on/off and I'll help you out. I can custom make you anything you need in regards. Thanks guys for the referral. Quote Tony Candela - SMD Sales & Marketing Email me at [email protected] to learn about becoming an SMD Partner! Link to comment Share on other sites More sharing options...
